hiemsnox Posted June 28, 2010 Share Posted June 28, 2010 ok just posting a little info i found out the hard way. i picked up a set of dc sports headers yesterday, and when i went to install them they didnt fit... kept hitting the oil pan. so anyone that is running a b series motor like a gsr or one with vtec the oil pick up sits lower on these cars, resulting in a deeper oil pan... meaning headers or turbo down pipes need to be slightly longer just thought i let u guys know if u didnt Link to comment Share on other sites More sharing options...
DelSolSweetie Posted June 28, 2010 Share Posted June 28, 2010 are you sure you got the proper header? Link to comment Share on other sites More sharing options...
hiemsnox Posted June 28, 2010 Author Share Posted June 28, 2010 are you sure you got the proper header? the guy had pulled them off of his b20. i couldnt find anything online about the difference in b18 vs b20 but then i came across the oil pan vtec thing Link to comment Share on other sites More sharing options...
DelSolSweetie Posted June 28, 2010 Share Posted June 28, 2010 okay so its not that a b18 header header doesnt fit if the motor is swapped in something.. its a b20 header doesnt fit a b18 kinda crappy you bought it and now have no use for it Link to comment Share on other sites More sharing options...
hiemsnox Posted June 28, 2010 Author Share Posted June 28, 2010 okay so its not that a b18 header header doesnt fit if the motor is swapped in something.. its a b20 header doesnt fit a b18 kinda crappy you bought it and now have no use for it although im sure its true that a b20 header wont fit a b18. i still think that it has something to do with the fact that a non-vtec oil pan is more shallow Link to comment Share on other sites More sharing options...
Xeryon Posted June 28, 2010 Share Posted June 28, 2010 no, it probably has something to do with the fact it is a completely different engine block. just a thought... Link to comment Share on other sites More sharing options...
