cmgogo Posted February 15, 2010 Share Posted February 15, 2010 This household is now the proud owners of 2 sols my 95s solvic that you all have seen me working on since last year and now i am going to be flying to new mexico and picking up includes Powertrain: Stock block d16z6, freshly rebuilt with ~6k miles mated to an EX tranny AEM Fuel Pressure regulator Walbro fuel pump Garrett 50trim .42/.63 t3 turbo, freshly rebuilt with ~3k miles (note the turbine size) Earls SS oil feed line Turbosmart 38mm Racegate external wastegate Underground Racing cast turbo manifold custom 3" full turbo back exhaust, 3" CARB legal cat, and dual (inline) 3" high flow Magnaflow mufflers PLX M300 wideband as primary o2 sensor Apexi AVCR digital boost controller HKS SSQV BOV Very large GodSpeed FMIC 3" oversized aluminum radiator reinforced silicone couplers with T-clamps MSD External ignition coil MSD Dist cap MSD 8mm plug wires 0/1ga main batt ground, all other grounds bumped to 4ga Alt wire upgraded to 4ga also ACT streetlight flywheel (11lb) ACT heavy duty pressure plate ACT SS street disk Suspension / Handling / Braking: KYB AGX adjustable struts Underground Racing sleeve coilovers Underground Racing front camber kit Underground Racing rear camber kit Underground Racing rear LCA (accepts sway bars) Front upper strut brace, rear upper strut brace, & rear lower strut brace, brand unknown (dont remember, have had forever) EBC slotted/dimpled zinc plated rotors up front, (drums out back still) Hawk semi-metallic pads Goodridge SS brake lines on all 4 corners Integra GSR power rack & pinion, re-plumbed & converted to non-power. (quickest steering ratio available from OEM) Electronics: Chipped/socketed P06 converted to Vtec, fine tuned via Crome PRO (not hours, MONTHS of tuning) Ostrich + datalog cable wired to a USB hub, single retractible USB cable from glovebox allows for very quick tuning/logging simultaneously Additional gauges include boost/vac, oil pressure, fuel pressure, batt voltage, and everything the AVCR displays (boost, speed, tach, Injector duty cycle, gear, etc..) JVC indash dvd player with bluetooth, ipod, usb, XM radio, full A/V input, and backup camera with night vision. MTX Thunder Axe 6.5" components (currently bi-amped off of the deck), sub(s) & amp(s) change pretty regularly. Security: Viper 791xv 2way alarm with remote start aftermarket power locks & power trunk release All 3 windows can be rolled up & down via alarm remote, & both fronts also have 1 touch up & down from the switch (VERY handy). Blue LED mounted in center console & "VIPER" OEL LCD display in base of windshield Interior: Tenzo R steering wheel dstuning del Sol logo black/red floor mats black/red stitching shifter boot & ebrake boot Skunk2 40g weighted shift knob B&M billet short throw shifter Black door panels, rear panels, and headliner Doors, floor, rear wall, roof, rear quarters, and the entire trunk have all been covered in Dynamat sound deadener. (several layers might I add) power trunk release button installed in-cab Most of the interior panels have been replaced with OEM to freshen it up & replace broken parts. Exterior: MS design rear spoiler JDM rear license plate garnish smoke 1pc headlights clear corner reflectors blacked out custom LED rear tail lights 5% black tint with solid black windshield strip. (literally, you can barely even see the sun through it) 16" Enkei rims OEM mudguards This will be my dad's sol, and ill continue to build mine. As of right now mine has a rebuilt z6 waiting to get dropped in, and am in the process of setting up a turbo to mate to it. i however will be using a much smaller turbo than is on the sol im about to go pickup (smaller snail = faster spool) and am looking at doing a disco potato to reach peak boost at about 1700rpm (max out at about 7psi) with how I am looking at doing it, and the shop that is going to tune for me said I could reasonably sit at about 180hp with the other mods i will be doing. More pics soon Link to comment Share on other sites More sharing options...
lastresort576 Posted February 15, 2010 Share Posted February 15, 2010 so you post pix of it here and not SS? I thought it was White...? Link to comment Share on other sites More sharing options...
airjordan223 Posted February 15, 2010 Share Posted February 15, 2010 was that audiophyles? Link to comment Share on other sites More sharing options...
tallhamer88 Posted February 15, 2010 Share Posted February 15, 2010 yea it was Link to comment Share on other sites More sharing options...
cmgogo Posted February 15, 2010 Author Share Posted February 15, 2010 those pics are from solsociety. Hes detailing it now, hes going to email me some photos in next few days (hes got a new kid, so its cool, im not in a big hurry) Link to comment Share on other sites More sharing options...
