JesseCuster Posted September 13, 2009 Share Posted September 13, 2009 So i got to looking around at turbo kits they all look pretty good iv been looking at this one for a good while http://www.treadstoneperformance.com/produ...eries+Turbo+Kit but i wanted to get into building my own and realized i have no idea where to start SO, if someone could be so kind as to point me in the right drection (ie part names, pieces, good brands, websites, so forth, so on) that would be awesome THANKS (93 del sol s d15b7(want to eventualy swap for b18c)) Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 14, 2009 Share Posted September 14, 2009 well first you need to decide which motor you want to turbo, how much boost, etc. then we can help u build it Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 14, 2009 Author Share Posted September 14, 2009 well as i previously stated i have a d15b7 now and want to swap to b18 later so i need something that can easily be adapted to one or the other also, for the d15 i prob wont go over 8 psi just because i am not planning and doing much internal work do to the swap seems a waste of money a little however, i dont want something cheap because when i do get the b18 i plan on boosting high 20-22 psi Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted September 14, 2009 Share Posted September 14, 2009 WELL if you want to turbo and have it last you should build the whole motor.. aka none of the interals will swap and as for fuel delivery, manifolds, piping, etc its going to impossible or really hard to swap things.. you could probably use the turbo/intercooler/piping (maybe piping) and that'd be it i would figure out which one you want to build/boost then go from there and even if you DONT want to build internals i wouldn't recommend boosting a motor with a lot of miles.. just because the rings in your motor will be worn.. the whole motor is worn actually lol Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 14, 2009 Author Share Posted September 14, 2009 (edited) ok maybe i will try saying it defferently so i want to swap my d for a b but before i put the b in i want to have it completely rebuilt as in, go ahead and upgrade internals, and redo everything i can for performance so it will be a year or 2 before i can get that in in the mean time i want to boost what i have now 5-8 psi max and i know i cant just take the turbo of my d and through it on my b that will be takin into consideration when build it up so lead me to something i can put together that can boost a little for now but boost a lot later again, i know some parts will have to be change Edited September 14, 2009 by JesseCuster Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 14, 2009 Author Share Posted September 14, 2009 also, i know sometimes people upgrade there turbos as they go that can also be a possibility a smaller one for now and upgradable to a bigger turbo when i go b Quote Link to comment Share on other sites More sharing options...
Mitchness Posted September 14, 2009 Share Posted September 14, 2009 Go here. Read this. The process of turboing a non-factory turbo motor is long and in-depth. There are tons of stickies on related sites like Real Home Made Turbo and Turbo d16 that will explain and educate greatly on the subject while also recommending parts to pursue and parts to avoid. I too wanted someone to hold my hand when I decided to undertake this project, but quickly learned there is no one out there willing to do it because they all had to do it the hard way. Once I realized that and bit the bullet it became much easier and now I have a pretty good idea of what I want out of my motor and what equipment I'll need. Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 14, 2009 Author Share Posted September 14, 2009 awesome thanks so much for the info and links i will begin the researching now that i have a lead Quote Link to comment Share on other sites More sharing options...
Tko Posted September 14, 2009 Share Posted September 14, 2009 Get yourself a copy of Maximum boost http://www.amazon.com/Maximum-Boost-Turboc...e/dp/0837601606 Read it cover to cover. Its filled with great info that you just cant find on forums. Quote Link to comment Share on other sites More sharing options...
JesseCuster Posted September 14, 2009 Author Share Posted September 14, 2009 (edited) Great Will do thanks for the advice Also i must add the website that 93d3ls0l and mitchness sugessted ( http://www.beesandgoats.com/boostfaq/g2icturbo.html#Kit ) is AMAZING so big props to THEM if anyone has any questions about boosting, READ THAT Edited September 14, 2009 by JesseCuster Quote Link to comment Share on other sites More sharing options...
