delsoltina Posted September 13, 2009 Share Posted September 13, 2009 I have a 1993 Honda del sol S with a stock engine when I purchased the car it was bad from the start I had to replace the head gasket right away, and shortly after (about a week ago) had to put a new distributor in it. It bogs down alot and chokes some when the AC is on but I thought that was just an AC problem then when I went to drive it today, in neutral it only idles at about 100-200 rpms and almost dies, from what I can tell it drives fine in any other gear. There is a small ticking noise comming from the engine area don't know it that has any significance. I would really appriciate any advice drive my car for work so its much needed. Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 13, 2009 Share Posted September 13, 2009 I have a 1993 Honda del sol S with a stock engine when I purchased the car it was bad from the start I had to replace the head gasket right away, and shortly after (about a week ago) had to put a new distributor in it. It bogs down alot and chokes some when the AC is on but I thought that was just an AC problem then when I went to drive it today, in neutral it only idles at about 100-200 rpms and almost dies, from what I can tell it drives fine in any other gear. There is a small ticking noise comming from the engine area don't know it that has any significance. I would really appriciate any advice drive my car for work so its much needed. Silly question, but did you replace spark plugs after headgasket? Quote Link to comment Share on other sites More sharing options...
delsoltina Posted September 13, 2009 Author Share Posted September 13, 2009 Silly question, but did you replace spark plugs after headgasket? Yeah. They are almost brand new Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 13, 2009 Share Posted September 13, 2009 have you tried cleaning your IACV Quote Link to comment Share on other sites More sharing options...
delsoltina Posted September 13, 2009 Author Share Posted September 13, 2009 have you tried cleaning your IACV I gotta get to it when I get off work. What's the best way to go about doing it? Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 13, 2009 Share Posted September 13, 2009 I gotta get to it when I get off work. What's the best way to go about doing it? here's a quick procedure for cleaning it. buying a haynes manual for your car might be a good thing to have as well Quote Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 13, 2009 Share Posted September 13, 2009 I would remove your TB as well and clean the hell out of it. Will have to buy new gasket as well though! Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted September 19, 2009 Share Posted September 19, 2009 and adjust the idle... if you had to pull the head off a lot of other stuff got unscrewed and unbolted also and it could have been put back on wrong just stating the obvious Quote Link to comment Share on other sites More sharing options...
Tko Posted September 22, 2009 Share Posted September 22, 2009 Its your dizzy timming yo! Quote Link to comment Share on other sites More sharing options...
delsoltina Posted September 22, 2009 Author Share Posted September 22, 2009 No. It's not the timming I have adjusted it twice. Doesn't help. Sad day Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted September 23, 2009 Share Posted September 23, 2009 (edited) check the throttle cable! (thats the most obvious thing i can think of) Edited September 23, 2009 by DelSolSweetie Quote Link to comment Share on other sites More sharing options...
injectedPois Posted September 23, 2009 Share Posted September 23, 2009 here's a quick procedure for cleaning it. buying a haynes manual for your car might be a good thing to have as well Haynes are great to have, even if there is nothing wrong with the car, they are good references for helping others and learning things. As stated, clean your IACV, and try the throttle body. I've had some friends with a messed up idle, and cleaning the throttle body was a -to date- permanent fix. Give it a go mann, and good luck. Quote Link to comment Share on other sites More sharing options...
