mashguy Posted September 7, 2009 Share Posted September 7, 2009 Anyone know if there is a place that makes aftermarket door panels that are close enough in guality to the factory door panels?, and if so who is the cheapest with shipping?. Another question I have is about using seafoam in the fuel tanks. The car is carburated and I heard that if I put seafoam in the tank to clean everything out that there could be a possibility of something getting dislodged and plugging up the carb? Is that true?. Thanks in advance Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 7, 2009 Share Posted September 7, 2009 if you want OEM panels you can get new ones from Majestic Honda Quote Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 8, 2009 Share Posted September 8, 2009 ^ what he said Quote Link to comment Share on other sites More sharing options...
mashguy Posted September 8, 2009 Author Share Posted September 8, 2009 I'm looking for something cheap. Those ones are way outta my price range Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 8, 2009 Share Posted September 8, 2009 then your best bet is a junkyard. what is the problem with your current ones? you can always just reupholster them Quote Link to comment Share on other sites More sharing options...
mashguy Posted September 8, 2009 Author Share Posted September 8, 2009 It's weird the passenger side is fine. The driver side on the top is broken so it kindof hangs free. Don't know what caused it. It's on the crx I'm buying from my friend Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 8, 2009 Share Posted September 8, 2009 is the door panel itself broken or is it just one of the tabs on the back of it that hold it onto the door? Quote Link to comment Share on other sites More sharing options...
mashguy Posted September 8, 2009 Author Share Posted September 8, 2009 I think the tab, but the vinyl is ripped to. Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted September 8, 2009 Share Posted September 8, 2009 both of those can be fixed easily Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted September 8, 2009 Share Posted September 8, 2009 if your carb gets clogged by something.. then you are missing something important its called a filter Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted September 10, 2009 Share Posted September 10, 2009 if your carb gets clogged by something.. then you are missing something important its called a filter thats funny... ive ran seafoam in my old dual carb and never ran into any problems. and the point of seafoam is to clean the tank meaning its going to eat the crud from the bottom of the tank and turn it into a liquid basically and then itll go throw the carbs and then the motor and will clean the carbon build up prob smoke a little bit but other than that itll be fine Quote Link to comment Share on other sites More sharing options...
