94Whitesol Posted July 19, 2009 Share Posted July 19, 2009 Hi everyone, My input shaft bearing is making a slight noise. I wonder how long can I drive the car? THanks Quote Link to comment Share on other sites More sharing options...
Jeffkillsya Posted July 19, 2009 Share Posted July 19, 2009 how do you know it is your input shaft bearing? Input shaft bearing??? like on the transmission?? Quote Link to comment Share on other sites More sharing options...
lceah Posted July 19, 2009 Share Posted July 19, 2009 ya, explain more! Quote Link to comment Share on other sites More sharing options...
94Whitesol Posted July 20, 2009 Author Share Posted July 20, 2009 depress clutch, noise goes away. Release clutch, grinding sound appears. Quote Link to comment Share on other sites More sharing options...
Jeffkillsya Posted July 20, 2009 Share Posted July 20, 2009 how good does your car accelerate? how good does your clutch grip? good or bad? Quote Link to comment Share on other sites More sharing options...
94Whitesol Posted July 20, 2009 Author Share Posted July 20, 2009 Acceleration is normal. It has new clutch, pressure plate, and new throw out bearing. When the car stays still (cold start), it's hard to put in reverse sometime. Yes, it has new Honda Manual tranny fluid. Quote Link to comment Share on other sites More sharing options...
Jeffkillsya Posted July 20, 2009 Share Posted July 20, 2009 sometimes if you take the car to a tranny shop they will ride with you or drive the car and will tell you what she is doing. Quote Link to comment Share on other sites More sharing options...
kirbydelslow Posted July 25, 2009 Share Posted July 25, 2009 depress clutch, noise goes away. Release clutch, grinding sound appears. I have the exact same, identical, 100% problem. Quote Link to comment Share on other sites More sharing options...
Pballer2005 Posted July 26, 2009 Share Posted July 26, 2009 most likely isb, seems to be pretty common in d series transmissions. had the same thing happen to me. took it to a shop and had to pay $800. don't take it to a shop. if you can live without the car for a little while talk to ssr, you can ship ur tranny and have his shop repair it for prolly a couple hundred. or if you have a weekend and some tools you can do it yourself for the price of the bearing. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted July 31, 2009 Share Posted July 31, 2009 did you do the clutch job yourself? and was it making that noise before you did the clutch job? also reverse being hard to get into is normal on most honda transmissions, ecspecialy after the get some miles on them. honda likes to use spur gears for their reverse. Quote Link to comment Share on other sites More sharing options...
