hiemsnox Posted June 11, 2009 Share Posted June 11, 2009 ok so for the last month or so i have hearing kinda of a metal on metal sound coming from my front right wheel. it kinda has the sound of when metal is resting on another metal surface but then under breaking it slips. i only really hear it when the wheel is turning right and breaking or at slow speeds... i have been going through what it could be, ive taken the wheel off too but nothing seems loose. and i dont want to start with a whole suspension bushing set cause that takes alot of time to replace. anyone else have this problem, or ideas what it could be thats making the noise Quote Link to comment Share on other sites More sharing options...
lceah Posted June 11, 2009 Share Posted June 11, 2009 did you do anything to your car or change anything in it right before the noise appeared? It could be a bunch of things. Try lubing the front right wheel suspension and see what happens... Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted June 11, 2009 Author Share Posted June 11, 2009 did you do anything to your car or change anything in it right before the noise appeared? It could be a bunch of things. Try lubing the front right wheel suspension and see what happens... no i havent touched them in months. and all i do is drive about 70 miles a day 60 of it highway. what do u suggest for the form of lube? Quote Link to comment Share on other sites More sharing options...
Tubbith Posted June 11, 2009 Share Posted June 11, 2009 metal on metal and when turning right or breaking it slips.. almost like a clicking sound? or does it sound more like when a wheel bearing goes out? Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 11, 2009 Share Posted June 11, 2009 what do u suggest for the form of lube? Depends on what you are into. I hear astroglide is popular in some groups. My preference is that new his and hers warming KY. Lists of common noises. Pulsating clicking in relation to moving speed: Axle Constant grinding in relation to moving speed: wheel bearing Constant grinding that either starts or stops when you touch the brakes: brake system Clicking while turning: axle Single pop while turning: ball joints Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted June 11, 2009 Author Share Posted June 11, 2009 Depends on what you are into. I hear astroglide is popular in some groups. My preference is that new his and hers warming KY. Lists of common noises. Pulsating clicking in relation to moving speed: Axle Constant grinding in relation to moving speed: wheel bearing Constant grinding that either starts or stops when you touch the brakes: brake system Clicking while turning: axle Single pop while turning: ball joints i would say its a mix between the last two. axle and ball joint... its mostly only when i turn but it will pop a few times when i first start to brake Quote Link to comment Share on other sites More sharing options...
Xeryon Posted June 12, 2009 Share Posted June 12, 2009 Put your front end up in the air and see if there is any side to side wobble in the tire. When you grab the sides of the tire and torque it left and right it should slowly rotate the other front tire and the steering wheel simultaneously. If it has play in it you need tie rod ends. If you and wiggle it from top to bottom then you might need a ball joint on the top, bottom, or both. Quote Link to comment Share on other sites More sharing options...
Humphries Posted June 24, 2009 Share Posted June 24, 2009 no i havent touched them in months. and all i do is drive about 70 miles a day 60 of it highway. what do u suggest for the form of lube? wd40. grease. LPS Quote Link to comment Share on other sites More sharing options...
