drewkuch Posted May 30, 2009 Share Posted May 30, 2009 How do i set the stock timing on my 1.5 liter engine? I need the crank gear and cam gear positions. The engine is just sitting and looking at me, begging to go in the car, haha.....Thanks a bunch to whomever can help me out! Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted May 30, 2009 Share Posted May 30, 2009 timing light Quote Link to comment Share on other sites More sharing options...
drewkuch Posted May 30, 2009 Author Share Posted May 30, 2009 My belt is off. I need to set this timing before the light i'm assuming. Crank key up, pointer at notch, at tdc. Cam shaft gear "up". Correct? Anyone? Quote Link to comment Share on other sites More sharing options...
HoNdAanswerMaN Posted May 30, 2009 Share Posted May 30, 2009 I'm not exactly sure on the 1.5L but I think it's like the 1.6L the cam gears should say up on them and there will be dots on the sides of the gear these dots will be set flush with the top of the head and then place your crank gear dot at the arrow on the block just make sure #1 cylinder is at top dead center and not 180 degrees off!! Good Luck Quote Link to comment Share on other sites More sharing options...
Pballer2005 Posted May 30, 2009 Share Posted May 30, 2009 both gears up Quote Link to comment Share on other sites More sharing options...
drewkuch Posted May 31, 2009 Author Share Posted May 31, 2009 I got it timed i think...we will found out soon, ha. thanks guys Quote Link to comment Share on other sites More sharing options...
