nnoossss Posted May 1, 2009 Share Posted May 1, 2009 so ive got a major oil leak with the honda and its the main front head gasket which is a bitch to fix. But i was wonderin does that stop leak stuff work. Ive heard that it not only does it work most of the time it also could damage the engine. Link to comment Share on other sites More sharing options...
CleanGSR Posted May 1, 2009 Share Posted May 1, 2009 Used some in my wife's car and it helped a lot. I don't remember the brand I used but it's viscosity was almost like a syrup. Really helped seal up the leaks for a short term fix... Link to comment Share on other sites More sharing options...
Staninator Posted May 1, 2009 Share Posted May 1, 2009 My recommendation dude is to just get a new head gasket and replace that before you run into more trouble. It will save you money in the long run. Link to comment Share on other sites More sharing options...
Xeryon Posted May 1, 2009 Share Posted May 1, 2009 Depending on the severity of the leak the stops leak stuff does work. It won't stop a leak if an entire freeze plug is blown out or if the gasket is completely missing. Stop leak compounds are more intended for minor maintenance leaks then for actual damage repair. An example is my civic has a weeping head gasket. I lose about 1/2 quart every 3000 miles but do not have a blown or damaged head gasket. Stop leak material worked great in the case. Leaking is down to just one drip hear or there. Link to comment Share on other sites More sharing options...
nnoossss Posted May 2, 2009 Author Share Posted May 2, 2009 alright yea mines pretty bad so since i dont have the money to repair it im just gona have to keep puttin oil in. Link to comment Share on other sites More sharing options...
