h23vtc95accrd Posted April 20, 2009 Share Posted April 20, 2009 my 95 accord squeals when i put on the brakes. i put new pads on all four wheels but it still squeals im pretty sure i need new rotors but just wanted to make sure before i buy them any ideas?? Link to comment Share on other sites More sharing options...
Pballer2005 Posted April 20, 2009 Share Posted April 20, 2009 my 95 accord squeals when i put on the brakes. i put new pads on all four wheels but it still squeals im pretty sure i need new rotors but just wanted to make sure before i buy them any ideas?? what pads? did you bed them properly? Link to comment Share on other sites More sharing options...
nicolaselias Posted April 20, 2009 Share Posted April 20, 2009 i also had a lot of noise problems on my accord when using semi-metallic pads.. switched to wagner thermoquiet organic pads and all noise went away... the car came with ceramic (organic) and you should stick with that Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted April 20, 2009 Share Posted April 20, 2009 i forgot what that spray is called that we would spray on the rotors and pads when we put new ones on when i worked at midas... but it prevents new pads and rotors from squeeking.. ive always had squeeky brakes when i did it at my house and theyre new.. Link to comment Share on other sites More sharing options...
James Matteu Posted April 20, 2009 Share Posted April 20, 2009 I have never had new pads/rotors/brakes make any noise. I always follow the Helms manual instructions regarding the removal of both caliper pins and the replacement/refreshing of the molybdenum disulfate grafite lubricant both on the pins and behind the pads. Link to comment Share on other sites More sharing options...
Turtlehead Posted April 20, 2009 Share Posted April 20, 2009 Yes, did you coat the shims with Honda anit-squeal? If not I would start withi that. Link to comment Share on other sites More sharing options...
h23vtc95accrd Posted April 21, 2009 Author Share Posted April 21, 2009 Yes, did you coat the shims with Honda anit-squeal? If not I would start withi that. no i didnt where would i find honda anti squeal? never heard of it..... Link to comment Share on other sites More sharing options...
James Matteu Posted April 22, 2009 Share Posted April 22, 2009 Just go to the auto parts store and look for a lubricant that contains molybdenum disulfate and grafite; it will be the same stuff that Honda dealership provides with their pads. I have never had new pads/rotors/brakes make any noise. I always follow the Helms manual instructions regarding the removal of both caliper pins and the replacement/refreshing of the molybdenum disulfate grafite lubricant both on the pins and behind the pads. Link to comment Share on other sites More sharing options...
h23vtc95accrd Posted April 23, 2009 Author Share Posted April 23, 2009 Just go to the auto parts store and look for a lubricant that contains molybdenum disulfate and grafite; it will be the same stuff that Honda dealership provides with their pads. thanks Link to comment Share on other sites More sharing options...
ToyHondaNismo Posted April 23, 2009 Share Posted April 23, 2009 Buy premium ceramic brakes (organic brakes) and you should be fine. Link to comment Share on other sites More sharing options...
1ATony Posted April 28, 2009 Share Posted April 28, 2009 If you didn't already I'd do like what was mentioned above and put that anti squeak lube on the outside of the pad.As long as the brake pedal dosen't pulsate,and rotors aren't grooved the rotors should be ok. Link to comment Share on other sites More sharing options...
nnoossss Posted May 2, 2009 Share Posted May 2, 2009 lol mine do that too Link to comment Share on other sites More sharing options...
