cja3rd1983 Posted April 13, 2009 Share Posted April 13, 2009 Can a ZC block and a 1.6L SOHC V-TEC head work togather Link to comment Share on other sites More sharing options...
DelSolSweetie Posted April 17, 2009 Share Posted April 17, 2009 since no one anwsered your question there are three zcs DOHC non vtec ZC 1.6 SOHC non vtec zc 1.6 SOHC vtec zc that should answer your question Link to comment Share on other sites More sharing options...
Xeryon Posted April 17, 2009 Share Posted April 17, 2009 Well, it wouldn't answer the question but it should narrow things down a bit. The DOHC block would not be compatible. The SOHC blocks would be compatible, but if you have the non-vtec zc it would be a lot of hassle to install a vtec head. You would need the solenoid, different ecu and wiring. Finding which timing belt you need might be a nightmare. Link to comment Share on other sites More sharing options...
cja3rd1983 Posted April 17, 2009 Author Share Posted April 17, 2009 Thank you for helping me out with this information:) Link to comment Share on other sites More sharing options...
