GT4life Posted April 9, 2009 Share Posted April 9, 2009 I am new to this forum so I couldn't get much from searching. I was wondering if anyone has a write up or knows how to install side skirts. I imagine I will be able to do it myself if i get a good write up. Thanks Link to comment Share on other sites More sharing options...
airjordan223 Posted April 9, 2009 Share Posted April 9, 2009 well it depends on the quality of the sideskirts you get. if you get good ones, you can just put them up and bolt them on. most likely you may have to work with the fiberglass (if you get fiberglass ones) to get it to fit properly. Link to comment Share on other sites More sharing options...
GT4life Posted April 9, 2009 Author Share Posted April 9, 2009 So by working with the fiberglass you mean sanding mostly right? How do they bolt on? I thought they had something like body clamps or no? Link to comment Share on other sites More sharing options...
Pballer2005 Posted April 9, 2009 Share Posted April 9, 2009 are they for your celica? i have no idea how they would hook up on there but i think on my civic there are holes along the bottom for the factory skirts. the cheap ones probably just use an adhesive, which would most likely work but once it stuck on it's not coming off, and if the fitment isn't right it'll be more of a pain to get it right. Link to comment Share on other sites More sharing options...
GT4life Posted April 9, 2009 Author Share Posted April 9, 2009 Yeah they are for my Celica. So I imagine it wont be too difficult then just either adhesive or clamp on? Link to comment Share on other sites More sharing options...
Pballer2005 Posted April 9, 2009 Share Posted April 9, 2009 Yeah they are for my Celica. So I imagine it wont be too difficult then just either adhesive or clamp on? nah shoudn't be hard. i'm assuming by clamp you mean some kind of screw. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted April 10, 2009 Share Posted April 10, 2009 We bolt. We bolt. We no ha cramp. We bolt. Link to comment Share on other sites More sharing options...
nnoossss Posted April 10, 2009 Share Posted April 10, 2009 They should bolt on its pretty easy to do it. The fiberglass is easy as hell. U just mold that to ur body pretty much and sand it and ur good. Link to comment Share on other sites More sharing options...
GT4life Posted April 11, 2009 Author Share Posted April 11, 2009 Can someone describe the full procedure of molding for me? Link to comment Share on other sites More sharing options...
nnoossss Posted April 21, 2009 Share Posted April 21, 2009 pretty much wat it is is ur making the side skirt mold to ur body. So what most people do to mold is they use fiberglass or bondo. All ur doing is makin the side skirt part of ur car. So just mold the side skirt to the car itself. after u do that u sand the bondo/ fiberglass and primer and ur rdy to paint. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 21, 2009 Share Posted April 21, 2009 you dont have to mold them to your car. it does look better that way, but you'll have to most likely deal with cracking, and if you hit them with something youre in trouble. Link to comment Share on other sites More sharing options...
nnoossss Posted April 22, 2009 Share Posted April 22, 2009 true but he wants to mold them for some reason. U can prevent cracking but its not worth it to mold them its easy as hell to bolt them on. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 22, 2009 Share Posted April 22, 2009 true but he wants to mold them for some reason. U can prevent cracking but its not worth it to mold them its easy as hell to bolt them on. no you really cant prevent it, just delay maybe. fiberglass, bondo, and sheet metal all flex differently and thats what causes it Link to comment Share on other sites More sharing options...
nnoossss Posted April 23, 2009 Share Posted April 23, 2009 no you really cant prevent it, just delay maybe. fiberglass, bondo, and sheet metal all flex differently and thats what causes it true that. I only know that my friends is still not cracked and hes had his on there for bout 4 or 5 years we took bondo and put a layer under the side skirt then pressed the side skirt in it and molded the rest to the body but his is also a wide body kit so it didnt really matter how much more it stuck out with a little bondo under the side skirt. It does crack if it has a air bubble or deeper whole under the bondo which is y we did wat we did. Not disagreing with u or anything. Link to comment Share on other sites More sharing options...
