fishswimfast Posted January 30, 2009 Share Posted January 30, 2009 i have a 94 prelude vtec. ive had the car for about 2 years. a few months ago i could hear a knocking noise when under acceleration until about fourth gear. i replaced the driver side axle and sound still occurred. i finally ruled out that it was the half shaft bearing was loose and was spinning the axle base off axis. i replaced it last week. the driver side motor mount is bad and will be replaced soon. i now only hear a terrible scratching noise when clutch is applied. if i sit still and rev the engine..nothing. but when i rev the engine and barely engage the clutch, i can hear it scratching. but only happens when clutch is engaged. once i let off of the gas and cruise while still in gear the noise stops. could it be that the shaft is a piece of crap or that due to the shaft being removed a few times with the car jacked up really high allowed too much of the tranny fluid come out. or could it be the engine is torquing and making something to come unalligned? or something else? completely stumped. i could only hear the noise after i replaced the shaft. but the noise of the shaking could have been louder than the scratching. Link to comment Share on other sites More sharing options...
Kastigir Posted January 30, 2009 Share Posted January 30, 2009 Throw out bearing is failing. Link to comment Share on other sites More sharing options...
Kegger Posted January 30, 2009 Share Posted January 30, 2009 Ditto Link to comment Share on other sites More sharing options...
Tubbith Posted January 31, 2009 Share Posted January 31, 2009 x's 3 Link to comment Share on other sites More sharing options...
Humphries Posted February 2, 2009 Share Posted February 2, 2009 might be input shaft bearing. Link to comment Share on other sites More sharing options...
Nancy Posted February 2, 2009 Share Posted February 2, 2009 no you guys are all wrong. did you check the muffler bearings? sounds like all the typical symptoms. replace those and youre good to go. Link to comment Share on other sites More sharing options...
diablo2dusk Posted February 2, 2009 Share Posted February 2, 2009 no you guys are all wrong. did you check the muffler bearings? sounds like all the typical symptoms. replace those and youre good to go. hahaha, ive given people this diagnosis in the past as well..... Link to comment Share on other sites More sharing options...
Kastigir Posted February 2, 2009 Share Posted February 2, 2009 might be input shaft bearing. Mainshaft bearings make noise when the clutch is out. When it's in, the throwout bearing is being loaded, and thus making the noise. Link to comment Share on other sites More sharing options...
fishswimfast Posted February 28, 2009 Author Share Posted February 28, 2009 it was just the bad motor mount putting pressure on the intermediate shaft and the axle where it meets and pulling it back. Link to comment Share on other sites More sharing options...
