Mike's FS: thread consolidation Little bit of everything CLICK&#33
Mafdark
Honda
Del Sol 1995 Dash, bare: $40
GSR sway bar $20
No name tie bar $20
Del Sol trunk carpets $30
Del Sol rear glass
OBD2 to OBD1 dizzy adapter (2) http://rywire.com/store/obd2-dseries...631f3e0263bad: $25 each.
Complete D16Z6 swap: $450 with all peripherals. Willing to split trans from the rest.
interior trunk release complete: $100
complete ps setup $150
complete AC setup $100
Del Sol OEM tails: $60
red stripe Sol seats, no rails $50 for the pair small tear in each
EG rear disc conversion $200
Fastbrakes 11" rotor, integra caliper upgrade http://fastbrakes.com/shop/product_i...roducts_id=681
Unused, $550
Turbo Stuff
hose ends -10 AN
-10 line for oil drain
-6 line can be used for catch can or coolant
GT series drain fitting fits all GT turbos $15 http://store.summitracing.com/partde...5&autoview=sku
Charge Piping and Sard BOV: $275
Nearly brand new GT28RS turbo $800
synapse D-series ramhorn turbo manifold, T28 internal gate flanged
Synapse T28 flanged Downpipe
Universal:
Enkei RPF1's 4x100 15x7
currently with Advan A032R 225 tires.
PM me to discuss price
B&M oil cooler with SS lines and -10 line ends/fittings
4x100 14" wheels with mounted all seasons and unmounted snows:
all seasons on top, snows below.
Audio
Elemental designs E10k.14 (i think 14)
regaurdless, there are two of them, they sounded great when I had them hooked up in my sol, and they don't take up as much room as most other subs so they can be put just about anywhere. even in a truck.
they are this style:
$35 each.
Looks like the picture in my first post is not the same one. Mine are not as deep. Here is a picture of them when i had them installed in the car:
Application Outline
Spec
E10k Subwoofer
Sealed Enclosure
Yes
Vented Enclosure
Yes
Infinite Baffle
No
Car Audio Box Size Suggestions Outline
Spec
E10k Subwoofer
Sealed ( small )
0.4ft³
Sealed ( ideal )
0.5ft³
Sealed ( large )
0.7ft³
Vented ( ideal )
1.5ft³ Tuned to 30Hz
Vented ( DDLoud)
1.5ft³ Tuned to 35Hz
Car Audio Recommended Boxes / Blueprints
Frequency Response Information
Specifications
Qts: .48
Qes: .40
Qms: 4.2
Fs: 29.00Hz
Re: 3.6
Vas: 40L
Mms: N/Ag
Bl: 14.00T*m
SPL: 88dB
Sd: N/Acm²
Xmax: 12.0mm
Voice Coil: 50.0mm
Magnet Width: 4.900"
Cutout Diameter: 9.250"
Mounting Depth: N/A"
Weight: 0lb
Total Height: N/A"
Displacement: .07 ft³
Outside Diameter: N/A"
Everything located in Rochester NY, Prices are without shipping.
  • 3 weeks later...
Hey Maf waiting on those parts...get back to me Asap please.
I think I got back to you. If I didn't I don't know who you are. :thumbsup:
This weekend only!! GT28RS turbo with low miles for $600
T3 .63 housing available for another 100
  • 1 month later...
  • 1 month later...
