alex37211 Posted December 10, 2008 Share Posted December 10, 2008 It wasn't doing this before, but when I drove it the other day, it was smooth as long as I didn't get more than maybe 60-70% into the gas pedal. But as soon as I would floor it, the rpms stopped climbing and the engine made a strange noise like like it was sputtering. It's kind of hard to explain the sound. Almost like rolling your tongue. Or like a submachine gun with a silencer on 007 Goldeneye. lol Oh and what's weird is my 4 door did the EXACT same thing last night when it was raining really heavy. Like maybe the cone filter was wet and so not enough air was coming in when the throttle body opened wide. Then when I was in a drive-through line, in neutral, I slammed on the gas and it instantly died. The rpms went straight down. This morning (now that it dried up a little) it ran perfect again. So I assume the problem had to do with the rain. My hatchback, however, showed this problem with blue sunny skies. And with 2 different air filters. One of which looked clean. ideas? Link to comment Share on other sites More sharing options...
..SSR.. Posted December 12, 2008 Share Posted December 12, 2008 CEL? TPS, TDC, or CKP sensors. The noise you're hearing is the engine missing. Link to comment Share on other sites More sharing options...
Xeryon Posted December 12, 2008 Share Posted December 12, 2008 Would be funny if it was the old broken cat trick again. Link to comment Share on other sites More sharing options...
alex37211 Posted December 12, 2008 Author Share Posted December 12, 2008 CEL? TPS, TDC, or CKP sensors. The noise you're hearing is the engine missing. Well it's still missing an o2 sensor. That's the only code it's throwing. I checked a while back, but I'll check again now that it's doing this. Somebody told me it may be moisture in my distributor. Link to comment Share on other sites More sharing options...
