hondaguyyy Posted October 13, 2008 Share Posted October 13, 2008 I am planning on painting the hood of my car. I was told by someone that I needed to wet sand my hood before I paint it. Would something like this work? http://www.autobodytoolmart.com/p-12829-15974.aspx Link to comment Share on other sites More sharing options...
alex37211 Posted October 13, 2008 Share Posted October 13, 2008 Just get 800-1000 grit sand paper and a pale of water. Keep on dipping the sand paper in the water every 30 seconds or so or as needed to keep it wet. Link to comment Share on other sites More sharing options...
airjordan223 Posted October 13, 2008 Share Posted October 13, 2008 I am planning on painting the hood of my car. I was told by someone that I needed to wet sand my hood before I paint it. Would something like this work? http://www.autobodytoolmart.com/p-12829-15974.aspx yes that will work, but you could also just use a hard sponge and get the same effect Link to comment Share on other sites More sharing options...
nnoossss Posted February 27, 2009 Share Posted February 27, 2009 I am planning on painting the hood of my car. I was told by someone that I needed to wet sand my hood before I paint it. Would something like this work? http://www.autobodytoolmart.com/p-12829-15974.aspx [yea sand it down when the hood is dry after sanding it the whole thing should b milky looking like foggy then u kno u got the whole hood good.] Link to comment Share on other sites More sharing options...
C92hatchX Posted February 27, 2009 Share Posted February 27, 2009 so i take it to paint a car you have to wet sand the whole thing first? Link to comment Share on other sites More sharing options...
nnoossss Posted February 28, 2009 Share Posted February 28, 2009 so i take it to paint a car you have to wet sand the whole thing first? well if u want it to look nice u do the paint will stick alot better. The paint job will look alot cleaner and u can make shure that ur not painting over anything like a piece of dirt or w/e could b around but just make sure wen u paint a car its sanded nicely doing so will make it look alot better Link to comment Share on other sites More sharing options...
C92hatchX Posted March 1, 2009 Share Posted March 1, 2009 what grit should i use?...im painting the whole car tomorrow Link to comment Share on other sites More sharing options...
nnoossss Posted March 1, 2009 Share Posted March 1, 2009 what grit should i use?...im painting the whole car tomorrow well wat u wana do is just sand the hood or w/e ur paintin down with 1000, make shure ur usin a flat surface like a sandin block or somethin. make shure that u keep the surface of the sand paper clean and keep the are wet once uve sanded a certain spot ull notice the paint to get dul then just clean it off and the whole thing should look like dull and kinda cloudy Link to comment Share on other sites More sharing options...
C92hatchX Posted March 1, 2009 Share Posted March 1, 2009 well wat u wana do is just sand the hood or w/e ur paintin down with 1000, make shure ur usin a flat surface like a sandin block or somethin. make shure that u keep the surface of the sand paper clean and keep the are wet once uve sanded a certain spot ull notice the paint to get dul then just clean it off and the whole thing should look like dull and kinda cloudy ok so sand with 1000, keep it wet..... , when it dull and cloudy after i clean it off...its ready to paint? Link to comment Share on other sites More sharing options...
nnoossss Posted March 4, 2009 Share Posted March 4, 2009 ok so sand with 1000, keep it wet..... , when it dull and cloudy after i clean it off...its ready to paint? yessir Link to comment Share on other sites More sharing options...
nnoossss Posted March 6, 2009 Share Posted March 6, 2009 How did it turn out? Link to comment Share on other sites More sharing options...
C92hatchX Posted March 6, 2009 Share Posted March 6, 2009 it came out great go check my update thread in the crx section Link to comment Share on other sites More sharing options...
