jerrodh Posted September 21, 2008 Share Posted September 21, 2008 The cable release (inside the cab) from all my knowledge appears to still be working meaning there isn't any slack really. It may be streched but when I pull the lever and then release the cable goes right back into the hose housing it came out of. I tried using plyiers to pull the cable out a little more but no luck and didnt want to snap it. Any idea how to get the hood unlocked an alternate way? and how to fix/how much? Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 21, 2008 Share Posted September 21, 2008 The cable release (inside the cab) from all my knowledge appears to still be working meaning there isn't any slack really. It may be streched but when I pull the lever and then release the cable goes right back into the hose housing it came out of. I tried using plyiers to pull the cable out a little more but no luck and didnt want to snap it. Any idea how to get the hood unlocked an alternate way? and how to fix/how much? Pull on cable and have some one hit front of hood! Its a ford! Link to comment Share on other sites More sharing options...
jerrodh Posted September 21, 2008 Author Share Posted September 21, 2008 *faceplant* Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 21, 2008 Share Posted September 21, 2008 No? Link to comment Share on other sites More sharing options...
jerrodh Posted September 21, 2008 Author Share Posted September 21, 2008 If I didn't like you I'd have to say you bug me alot. :glare: Link to comment Share on other sites More sharing options...
Xeryon Posted September 22, 2008 Share Posted September 22, 2008 Get under it, and get to the latch from underneath. On some setups you can also reach the latch through the grill with a long screwdriver. Link to comment Share on other sites More sharing options...
jerrodh Posted September 22, 2008 Author Share Posted September 22, 2008 Alright I'll try a screwdriver, but is it essentially "locked" at all? Link to comment Share on other sites More sharing options...
Xeryon Posted September 22, 2008 Share Posted September 22, 2008 If the lever is pulled in the cab then it is either A: Stuck latch and hitting it with a screwdriver will pop the hood, or B: the cable is actually broken and you will have to use your screw driver to active the lever by hand. Link to comment Share on other sites More sharing options...
jerrodh Posted September 22, 2008 Author Share Posted September 22, 2008 Alright thanks Jason guess I'll take the screw driver out tomorrow. Gotta get this hood up so I can oil it up and get new tires on for this weekend trip. Link to comment Share on other sites More sharing options...
