94gsr Posted November 21, 2007 Share Posted November 21, 2007 94 GSR, intake, header, exhaust, intake manifold. 120,000 miles. The other day i was driving it, pulled out of a parking lot, brought it up to about 4500rpm, shifted in to second, then third, and then it died. And then it didnt start back up, at all. The motor tries to start, but doesn't kick over. Any ideas would be appreciated... -Not sure if this is relevant, but my friends van did something like this. They ran a bunch of electrical tests, and it turned out to be a bad fuel pump. It wasn't pumping enough fuel, but was still turning on. - Mine is still turning on, well, sounds like it is. Link to comment Share on other sites More sharing options...
Ben. Posted November 21, 2007 Share Posted November 21, 2007 So it ran fine until it died? Link to comment Share on other sites More sharing options...
94gsr Posted November 21, 2007 Author Share Posted November 21, 2007 So it ran fine until it died? Yes sir... Link to comment Share on other sites More sharing options...
Ben. Posted November 21, 2007 Share Posted November 21, 2007 Doesn't SOUND like it's getting fuel but if you're saying the pump is functional. Link to comment Share on other sites More sharing options...
94gsr Posted November 21, 2007 Author Share Posted November 21, 2007 Doesn't SOUND like it's getting fuel but if you're saying the pump is functional. Thats what I thought, but ya know how you can hear when it kicks on if you have the key turned, well I'm pretty sure I hear it, although I could be wrong. I also unhooked the fuel line from the fuel rail, and it squirted fuel out. Maybe injectors? Link to comment Share on other sites More sharing options...
Kegger Posted November 21, 2007 Share Posted November 21, 2007 Check your ecu fuse and then the fuse for the PGM-FI. Link to comment Share on other sites More sharing options...
94gsr Posted November 21, 2007 Author Share Posted November 21, 2007 Check your ecu fuse and then the fuse for the PGM-FI. Checked the ECU fuse, and that was fine. Where abouts would the PGM-FI be located? Link to comment Share on other sites More sharing options...
Hatch92 Posted November 21, 2007 Share Posted November 21, 2007 when it turns over you never hear it even try to pop off? it would be a rotor also pull the cap off the distributor to make sure it didn't come apart. mine did a while back. Link to comment Share on other sites More sharing options...
lceah Posted November 21, 2007 Share Posted November 21, 2007 timing? vaccum leaks? test possibilities one by one... Link to comment Share on other sites More sharing options...
TS John Posted November 21, 2007 Share Posted November 21, 2007 I was gonna suggest what Kegger suggested, since that's happened to both of us... ...with the same damn car... Link to comment Share on other sites More sharing options...
cranny Posted November 21, 2007 Share Posted November 21, 2007 definitely somin to do with the dizzy , be it a coil , ICM , or CPS sensor. find one of your buddies with a DOHC VTEC engine of the same OBD and try thier dizzy. Link to comment Share on other sites More sharing options...
tantrumcrx Posted November 25, 2007 Share Posted November 25, 2007 definitely somin to do with the dizzy , be it a coil , ICM , or CPS sensor. find one of your buddies with a DOHC VTEC engine of the same OBD and try thier dizzy. Yup check spark... Link to comment Share on other sites More sharing options...
94gsr Posted November 29, 2007 Author Share Posted November 29, 2007 definitely somin to do with the dizzy , be it a coil , ICM , or CPS sensor. find one of your buddies with a DOHC VTEC engine of the same OBD and try thier dizzy. thanks, i will hopefully get around to that soon and let you guys know. its funny, i was just thinkin, abotu 5 or 6 of my buddies all bought integras after i got mine, and everyone made a big deal about how we all have the same car and whatnot, and they all have 96 and up! what luck. thanks guys Link to comment Share on other sites More sharing options...
94gsr Posted January 5, 2008 Author Share Posted January 5, 2008 definitely somin to do with the dizzy , be it a coil , ICM , or CPS sensor. find one of your buddies with a DOHC VTEC engine of the same OBD and try thier dizzy. replacing distributor... just get a stock one, or should i upgrade? Link to comment Share on other sites More sharing options...
Kegger Posted January 5, 2008 Share Posted January 5, 2008 Stock is just fine. Link to comment Share on other sites More sharing options...
Xeryon Posted January 5, 2008 Share Posted January 5, 2008 make sure the place you buy it at has a good return policy - if you didn't borrow one to test with first. honda disti are expensive and it would suck if it turned out to not be the problem and you couldn't return it. Although I haven't known cranny to be wrong on things like this, I just try to play it safe myself. Link to comment Share on other sites More sharing options...
cranny Posted January 6, 2008 Share Posted January 6, 2008 thinking on this further , whoever mentioned a broken timing belt , i think i read someone did , could be right. be a good idea to whip your dizzy cap off and make sure the rotor turns when engine is cranked. Link to comment Share on other sites More sharing options...
Hatch92 Posted January 6, 2008 Share Posted January 6, 2008 i said that and iceah said timing. i mean i had the screw on the rotor come off mine a long time ago. that cause me to have the same thing he had. i was driving then all of a suddon the car shut off. tried to start it and it didn't even pop off it just turned over. Replaced the cap and rotor and she was good as new. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 10, 2008 Share Posted January 10, 2008 Kegger's right check your PGM Sensor, thats more than likely your problem, i've had the same problem with my g20, and it turned out to be a Mass Air Flow Sensor, same concept. Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted January 11, 2008 Share Posted January 11, 2008 Kegger's right check your PGM Sensor, thats more than likely your problem, i've had the same problem with my g20, and it turned out to be a Mass Air Flow Sensor, same concept. Does the cranking rhytm sound the same as before? if not you broke the timing belt or jumped a couple of teeth. as far as buying a part to check if its the problem and returning it because it didn't fix the problem is wrong and some places will not refund you the cash, well there not suppose to. My shop teacher use to call these witch hunts. People will do that till they find out what works. Diagnosis the problem and repair it right. Link to comment Share on other sites More sharing options...
94gsr Posted January 17, 2008 Author Share Posted January 17, 2008 Does the cranking rhytm sound the same as before? if not you broke the timing belt or jumped a couple of teeth. as far as buying a part to check if its the problem and returning it because it didn't fix the problem is wrong and some places will not refund you the cash, well there not suppose to. My shop teacher use to call these witch hunts. People will do that till they find out what works. Diagnosis the problem and repair it right. havent had any time to even think about doing anything to my car. i replaced the rotor, and it did nottin. i will try what cranny said either tomorrow or sometime this weekend. and i dunno if i said this already, but we checked for spark at the end of the wires, and there was none. <-unless that changes something... thanks again. and im pretty sure it sounds the same... Link to comment Share on other sites More sharing options...
