ducttape2334 Posted November 19, 2007 Posted November 19, 2007 a family friend has all the necessary equipment to paint a car and a place to do it. My question is how many gallons of primer, paint, and clear coat would i need? I am going to try for a jet black or maybe a metallic blue undecided as of it right now. Thanks
Ben. Posted November 19, 2007 Posted November 19, 2007 Gallon of base should do it. Depending on how deep/wet you want the paint to look..could vary on the clear. Use as much primer as you want. Just don't skimp it.
Kegger Posted November 19, 2007 Posted November 19, 2007 Three layers of primer with a coat of sealer after each, two to three coats of base. Eyeball the clear. Buff and polish.
airjordan223 Posted November 19, 2007 Posted November 19, 2007 yeah i just repainted my car last summer, cant remember how much, but it doesnt take a lot to cover a sol
ussamah Posted November 29, 2007 Posted November 29, 2007 when you guys spray your own cars, do you rent out special spray booths or do you just clean out your garage and use that?? how good did it come out??
CleanGSR Posted November 29, 2007 Posted November 29, 2007 The guy that painted my old car (he was a pro) did it at his new shop and didn't have a paint booth yet. He did have a seprate closed off section of his garage for spraying cars though. I just sprayed down the floor with water before painting to keep dust from kicking up, then he wetsanded and buffed any dust that got in the paint. Came out looking better than any paint I've seen period.
CRG7 Posted November 30, 2007 Posted November 30, 2007 With the last sprays, neither my Sol or CRX were done in booths. CRX was done in my garage. Both came out fine.
Ben. Posted November 30, 2007 Posted November 30, 2007 My old hatch which started it's life as Vogue Silver Metallic, was repainted to Toyota's Super Red. Needless to say, it was done in a dual-car carport with bisquine on the ground and the sides/back/front enclosed. Came out awesome. Probably cheapest route, too. Unless you have a garage or something like that already setup.
Pyrorocketeer Posted November 30, 2007 Posted November 30, 2007 Three layers of primer with a coat of sealer after each, two to three coats of base. Eyeball the clear. Buff and polish. you shouldn't be spraying a coat of sealer in between each layer of primer 3 layers of high build, 1 or 2(if all underneath isn't hidden) of your primer sealer, then base, clear.
rodder-tuner214 Posted December 3, 2007 Posted December 3, 2007 its not how good of a painter you are its how you fix your f*ck ups
ussamah Posted December 23, 2007 Posted December 23, 2007 as iv only got a single garage its unlikely ill be able to get round my car with ease so ill probably have to take off as many panels as possible and do them separately.. i was just wondering, do the rear panels on an EG6 come off?? and what are the minimum specs of air compressor and spray gun do i need?
Hatch92 Posted December 23, 2007 Posted December 23, 2007 you could always do it outside in an open yard. we did my old man's bronco outside and it came out real well actually.
ussamah Posted December 23, 2007 Posted December 23, 2007 what about dust and sh!t??? i live in a very suburban area, i cant see my neighbours, who are middle-aged baby boomers, being too happy with some punk spraying chemicals' on his car on the side of the road what about the aircompressor and spray gun, whats the minimum spec i need?? thanks
Ben. Posted December 23, 2007 Posted December 23, 2007 You can do it in your yard..just make sure you hose the area down and lay down some bisquine or something on the ground. And keep it away from tree's. My EJ6 was an outside of a shed/house paintjob and the only thing that was wrong with it was the fact it had minor orange peel beneath the clear on one door.
airjordan223 Posted December 24, 2007 Posted December 24, 2007 if you do it outside, expect to do a lot of wet sanding afterwards to get rid of dust particles and other imperfections.
ducttape2334 Posted December 24, 2007 Author Posted December 24, 2007 my friend did hers outside on grass...what she did though was take steel tubes ($15 bucks) and build a mini garage around it...hung clear plastic on those poles...it let her adjust it on a day to day basis. she told me the whole setup cost her $55 bucks and an hour to set up. Worked great for her, if only the paint color was better haha.
Xeryon Posted December 24, 2007 Posted December 24, 2007 i was just wondering, do the rear panels on an EG6 come off?? that would be a negative, unless you like welding. it is a unibody car. the rear panels are technically part of the frame.
Repsol Posted December 24, 2007 Posted December 24, 2007 I soooooo want to get my car painted. It needs it sooo bad.
Hatch92 Posted December 24, 2007 Posted December 24, 2007 yours needs painted? hell mine is mismatched dark gray and primer black.
ussamah Posted December 24, 2007 Posted December 24, 2007 and should i use a spray gun/air compressor or would rattle cans do the trick?? im planning to use an air compressor as it will probably look a lot nicer and will be easier to do...but if i can get a good finish with a spray can it will be much cheaper!
Pyrorocketeer Posted December 24, 2007 Posted December 24, 2007 you won't get a good finish with f-ing rattle can paint.... plus that crap won't last very long on your car
Repsol Posted December 24, 2007 Posted December 24, 2007 HRP is going to look sexy on the sol with the flat black Buddy Club's.
CRG7 Posted December 24, 2007 Posted December 24, 2007 Flat black looks great when done correctly, and on the right car. Rattle-canning will not be cheaper, unless you're talking about your basic spray paint and minimal effort. I think the PPG rattle cans I got for the CRX's engine bay were about $13/can. An 80 gal compressor and some Snap-On gun were used to spray my CRX. Not sure if the amount of air in the compressor or spraying too close was the cause for the orange peel on the passenger side, maybe a combination of both.
