nosaj81_2000 Posted February 4, 2003 Share Posted February 4, 2003 does any one know what motor the 91 civic lx motor specs or what type of motor. Link to comment Share on other sites More sharing options...
BuddySol Posted February 4, 2003 Share Posted February 4, 2003 I believe your other has covered that question http://www.hondaforums.com/index.php?act=S...f=47&t=1846&hl= Link to comment Share on other sites More sharing options...
ImportGirl82 Posted February 4, 2003 Share Posted February 4, 2003 the putts said he didnt realize he made another one just like mine...men...lol... Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 5, 2003 Author Share Posted February 5, 2003 so whatdo you people suggest that i do with the motor performance wise. right now it has a after market exhaust except for the header and the intake is the sock intake with holes drilled into the black rubber/plastic air intake hose. right now that is all that i have noticed. also the a/c is there but its not hooked up should i discard of the a/c componants ot should i get the a/c lines that connect to the compressor? Link to comment Share on other sites More sharing options...
optional187 Posted February 6, 2003 Share Posted February 6, 2003 i would suggest putting on a aftermarket intake and header then. as for the a/c. it depends on what you want and how hot it gets in your area. i usually roll with the windows down in my car (even in the winter ) but i still want my a/c. you know, for those days that its raining and hot. a/c is a good thing. but if you don't really care about a/c then just rip all that stuff out and save some weight... Link to comment Share on other sites More sharing options...
BuddySol Posted February 6, 2003 Share Posted February 6, 2003 As much as I praise the A/C in the car, hahaha I rarely use it. On 100+ hot days, when you got the blower on full blast with the temp on the most extreme hot (or cold) and the glass still won't clear, and days when I wash the car are the only times I use A/C. All the other times I drive with the windows open and on a good day, I'm taking off the roof Link to comment Share on other sites More sharing options...
optional187 Posted February 6, 2003 Share Posted February 6, 2003 yeah dude, i always...always...roll with the windows down and the sunroof open. and if its cold, i just crack the sunroof and turn the heater up but on those hot days and you get stuck in a traffic jam cause of a wreck or something...a/c is very good. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 6, 2003 Author Share Posted February 6, 2003 cool thanx guys also how do i get the heat to work a little better than it does now. i have replaced the thermostat (yesterday). any suggestions. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 6, 2003 Author Share Posted February 6, 2003 can i use d16a engine componants on a d15a engine. Link to comment Share on other sites More sharing options...
..SSR.. Posted February 6, 2003 Share Posted February 6, 2003 If you hook the A/C back up, make sure you put a liquid line filter on it to get any bad stuff out of it that might have gotten into it. Link to comment Share on other sites More sharing options...
S14Silvia Posted February 6, 2003 Share Posted February 6, 2003 can i use d16a engine componants on a d15a engine. you can but you have to bore out the cylinders to allow them to fit, d15=1.5ltr, d16=1.6ltr. personally i think its too much work for hardly any gain. Link to comment Share on other sites More sharing options...
optional187 Posted February 6, 2003 Share Posted February 6, 2003 d16a? thats a new code that i've never heard. d16z6... Link to comment Share on other sites More sharing options...
S14Silvia Posted February 6, 2003 Share Posted February 6, 2003 D16a6 SOHC 108 hp 100 ft-lbs 7100 rpm red line Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 8, 2003 Author Share Posted February 8, 2003 oops.... i meant the b16a motor. Link to comment Share on other sites More sharing options...
S14Silvia Posted February 8, 2003 Share Posted February 8, 2003 then no you cant use b16a engine internals on a d15. Link to comment Share on other sites More sharing options...
optional187 Posted February 8, 2003 Share Posted February 8, 2003 what car was the d16a6 in s14? was it the hx or something? cx maybe...? Link to comment Share on other sites More sharing options...
BuddySol Posted February 8, 2003 Share Posted February 8, 2003 the CRX Si I believe Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 8, 2003 Author Share Posted February 8, 2003 what i referring to as per the b16a motor is that will i be able to fit one in the engine bay an what are the specs on it if any one knows them. Link to comment Share on other sites More sharing options...
S14Silvia Posted February 8, 2003 Share Posted February 8, 2003 the d16a6 i think was in the crx si.. yes a b16a will fit in any civic, integra, crx chassis after like 1989. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted February 26, 2003 Author Share Posted February 26, 2003 well i was looking at my motor and i noticed that i have a D16A motor. when the ? was asked ealier on what type of motor i had this is what i got as a reply from BuddySol in a different thread. is there anything out there for this motor or should i still go ahead and get a b16a next tax season? 91 Civic DX? D15A 92hp@6000rpm 89lb-ft@4500rpm Link to comment Share on other sites More sharing options...
BuddySol Posted February 26, 2003 Share Posted February 26, 2003 Oh...hmmmm, maybe it was different...hmmm, let me go look it up... Well the DX, LX should be D15A, while the EX would be a D16A6 Link to comment Share on other sites More sharing options...
optional187 Posted February 26, 2003 Share Posted February 26, 2003 it should be a d15 but maybe somebody swapped in a d16a6? i'm not sure but is the d16a6 vtec? should be i think...does it say vtec on it? lol. d16z6 (all ex's and si's from 92-95) is vtec. Link to comment Share on other sites More sharing options...
BuddySol Posted February 26, 2003 Share Posted February 26, 2003 No, I don't think the D16A6 is a VTEC since it was introduced in Japan on the Integra in like 89. VTEC didn't make it to the Civics till 92. Link to comment Share on other sites More sharing options...
nosaj81_2000 Posted March 4, 2003 Author Share Posted March 4, 2003 No, I don't think the D16A6 is a VTEC since it was introduced in Japan on the Integra in like 89. VTEC didn't make it to the Civics till 92. i think you are right about that buddy sol. now another ? if i post the block serial # could anyone find out what motor this is exactly. because i went to honda.com and found out that the ex and the Si of the same time frame of my car also used this motor. the EX version having about 108hp and Si about 113hp. Link to comment Share on other sites More sharing options...
