cranny Posted May 5, 2006 Share Posted May 5, 2006 power to you. although makes no sense to me. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 5, 2006 Share Posted May 5, 2006 How does it not make sense? Link to comment Share on other sites More sharing options...
cranny Posted May 6, 2006 Share Posted May 6, 2006 not even startin with you monkey , lol. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 6, 2006 Share Posted May 6, 2006 Monkey? I think someone is just mad because they have no logical answer for this one. Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 6, 2006 Author Share Posted May 6, 2006 either way does anyone have an answer on how i could tell the difference by looking at it? Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 6, 2006 Share Posted May 6, 2006 Nah man. I'll ask around for you today? I'll get back at you tonight. Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 6, 2006 Author Share Posted May 6, 2006 thanks bro i'd appreciate it. Link to comment Share on other sites More sharing options...
cranny Posted May 7, 2006 Share Posted May 7, 2006 just call the dealer on the phone dew , and give them the number thats next to the engine code(B18B1). theyl prolly be able to tell you , or point you i right direction. Link to comment Share on other sites More sharing options...
cwd14 Posted May 7, 2006 Share Posted May 7, 2006 I don't really no much about this stuff but I have been looking into the b16's lately since I am about to do an engine swap and the B16A SIR I (JDM) is OBD0 SIR II (which I think is USDM) is ODB1. I guess this could be wrong but I did read it someplace on the internet haha. so really if it is an 88-91 b16 then it is obd 0 from my understanding. 92-95 is obd 1 and I guess 96-2000 is obd 2 Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 7, 2006 Author Share Posted May 7, 2006 yeah, i know that, but the problem is is that they're all b16a, so the only way to tell the difference, is well i dunno. Link to comment Share on other sites More sharing options...
cwd14 Posted May 7, 2006 Share Posted May 7, 2006 yeah, i know that, but the problem is is that they're all b16a, so the only way to tell the difference, is well i dunno. hmm maybe you are right I do recall reading somewhere that B16A with no number is jdm so maybe all jdm's are b16A haha. but I just remembered that the distributors are different between the different obd's so maybe if you can fnd pictures of the plugs you would be able to tell. but once again I got this info from browsing through forums haha. OH lol I juuuust remembered I think you can tell from reading the valve cover and seeing which words are bigger. I think on obd0 the word "DOHC" is bigger than the "Vtec" or something like that. I think I read that somewhere on hondaforums or hondaswap or something. but I think that will only eliminate obd0 because obd1 and obd2 both have the same valve covers here is what I got from the thread How to tell the difference between an SiR and an A2/A3/SiR II * SiR uses a cable tranny- 5th gens are hydraulic * SiR has a lower compression ratio, 10.2:1 and makes 160ps * A2/A3/SiR II have a higher compression ratio at 10.4:1 and make 160hp (A2/A3) or 170ps (SiR II) * A2/A3/SiR II motors have a better cam profile * A2/A3/SiR II have better oiling functions, keeping things better lubricated * SiR has cast aluminum oil spray bars while the A2/A3/SiR II are made of extruded aluminum. * A2/A3/SiR II have a single- 4-wire O2 sensor instead of 2-single wire O2 sensors * A2/A3/SiR II MAP sensor is an integral part of the throttle body, not an external one with a tube. * A2/A3/SiR II harnesses are grey. SiR has cream colored ones. * SiR is PGM-F1, clearly labeled on the intake manifold, andA2/A3/SiR II are MPFI * SiR valve covers have "DOHC" written in a larger font size than "VTEC" * A2/A3/SiR II valve covers have "VTEC" written in a larger font size than "DOHC" there ya go problem solved!(I think) http://www.hmotorsonline.com/shop/sc2000se...page&item=30021 (89-91 DOHC is bigger) http://www.hmotorsonline.com/shop/sc2000se...page&item=30022 (92-95 VTEC is bigger) Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 7, 2006 Author Share Posted May 7, 2006 thanks meng i'll have to go with the valve cover, as its only engine + block lol, thanks!!! Link to comment Share on other sites More sharing options...
cwd14 Posted May 7, 2006 Share Posted May 7, 2006 thanks meng i'll have to go with the valve cover, as its only engine + block lol, thanks!!! no problem Link to comment Share on other sites More sharing options...
cwd14 Posted May 9, 2006 Share Posted May 9, 2006 did you check out the block? was it obd1 or obd0? sorry I am just curious haha Link to comment Share on other sites More sharing options...
mountaindewguy Posted May 10, 2006 Author Share Posted May 10, 2006 obd0 pgm intake manifold DOHC is larger. gay. Link to comment Share on other sites More sharing options...
