Batman Posted February 16, 2006 Share Posted February 16, 2006 Is a GSR head the same thing as a V-TEC head? If not what makes it a V-TEC? I know its probably a bumb question but I need help !!! Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 See thats what I mean... Im not gone five mine and its pushed to the back !!! Link to comment Share on other sites More sharing options...
CleanGSR Posted February 16, 2006 Share Posted February 16, 2006 A GSR head is a vtec head, but so are many other heads. Any motor that is vtec has a vtec head. OH, and there is no dash between v and t. Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 Ok so I can use a GSR Head on my LS block and make it a LS VTEC? and how do I know if it a B18a,b,c? Link to comment Share on other sites More sharing options...
CleanGSR Posted February 16, 2006 Share Posted February 16, 2006 Yes Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 How do I know if I have a B18A,B,C ? and are all the B18 heads compatible? Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 It fawking did it agean !!! Link to comment Share on other sites More sharing options...
CleanGSR Posted February 16, 2006 Share Posted February 16, 2006 B18A and B are not VTEC heads and B18C is a VTEC head. You can tell if it's VTEC or not by the valve cover. Link to comment Share on other sites More sharing options...
..SSR.. Posted February 16, 2006 Share Posted February 16, 2006 Look at the cams. If there is more than one set of lobes, it is VTEC. Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 Ok but I can put a B18C head on a B18B block? Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 AAAAAARH. It keeps on doing this $h!t !!! Link to comment Share on other sites More sharing options...
CleanGSR Posted February 16, 2006 Share Posted February 16, 2006 Just an FYI, I won't be responding to any of your posts from now on. These meaningless posts are just pissing me off, so I'll be nice and just stay out of it. Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 Just an FYI, I won't be responding to any of your posts from now on. These meaningless posts are just pissing me off, so I'll be nice and just stay out of it. OK you say dont bump it so what the h3ll do I do when it disapers in the morning and there is not one topic on the bord? Pluss I have a B18A1, cand I put a GSR head ond it from a B18c? Link to comment Share on other sites More sharing options...
CleanGSR Posted February 16, 2006 Share Posted February 16, 2006 It only dissapears for you. Everybody that comes in later and clicks "View New Posts" will see it whether you bump it or not. It only dissapears for you because it's not a new post to you. Link to comment Share on other sites More sharing options...
Batman Posted February 16, 2006 Author Share Posted February 16, 2006 OOOH, OK sorry. But I have a B18A1 head, Can I still Put a B18C head on it? Link to comment Share on other sites More sharing options...
mountaindewguy Posted February 17, 2006 Share Posted February 17, 2006 to your last post, you cannot put a head on a head. if you meant b18a BLOCK, then, yes, with mods to the head, you can. i'll make this simple. if you have a b18a, or b18b, either one NON VTEC (off an LS,GS,or RS integra) is simply called an LS block. now the heads. 3 main heads are used for the LSVTEC setup. and pretty much the only ones that can be used. ALL 3 are VTEC. b16 - found on the del sol vtec, 99-00 civic si, the SIR (japan), etc.... b18C - Integra GSR b18c5 - Integra Type R - dont waste your money on this, its too expensive and you'll get the same results with the b16. those 3 will work. to put the head on a NON-VTEC block, you need to tap and plug the old oil supply hole, and machine the dowel holes, or buy the golden eagle kit and get the step down pins. then you have to unplug oil supply holes and re-locate where the oil gets fed into the head. Link to comment Share on other sites More sharing options...
