CRXSSIVE Posted January 31, 2006 Share Posted January 31, 2006 hi, I have a civic with a b 16a with no codes, I had a look @ the ecu while driving... no lights on. I checked the VTEC solenoild & cleaned it ... it works. it has no check engine light on...There is oil in the engine ... It does have oil pressure. Link to comment Share on other sites More sharing options...
Batman Posted January 31, 2006 Share Posted January 31, 2006 What is the problem? What is the car doing? Link to comment Share on other sites More sharing options...
CleanGSR Posted January 31, 2006 Share Posted January 31, 2006 Yeah, you didn't really give us the problem. Link to comment Share on other sites More sharing options...
cranny Posted January 31, 2006 Share Posted January 31, 2006 he said vtec is not engaging. i worked on a 92 gsr integra with a B16A swap last nite had 5 i repeat 5 trouble codes held in PCM. Also i discovered last nite this engine doesnt have a knock sensor on it at all(verybad for performance).So were down to one code anyways.But his vtec and the car overall works great , goes like a scolded cat. Link to comment Share on other sites More sharing options...
c0mmon Posted January 31, 2006 Share Posted January 31, 2006 my vw didnt have a knock sensor, that was for increased preformance Link to comment Share on other sites More sharing options...
CRXSSIVE Posted February 5, 2006 Author Share Posted February 5, 2006 well VTEC doesnot engage I've cleaned & tested the VTEC solenoid, it has no codes, my speedo works, the temp gauge works Link to comment Share on other sites More sharing options...
xxscaxx Posted February 6, 2006 Share Posted February 6, 2006 did you check the wiring? Link to comment Share on other sites More sharing options...
CRXSSIVE Posted February 10, 2006 Author Share Posted February 10, 2006 well there has to be a problem with the wiring. I checked oil pressure before & while jumperi'n the VTEC solenoid & there was a spike on the oil pressure gauge. was tracing back on the wires & found a wire besides the ecu which loes into the engine bay onto the big connector besides the fuse box... I compared the ecu connectior(civic jdm b16) with mine(crxjdm b16) I only managed to check the vss... wire which was unfortunately pluged in. Link to comment Share on other sites More sharing options...
CRXSSIVE Posted February 12, 2006 Author Share Posted February 12, 2006 I just checked all the wires that were connected to the ecu with my jdm b16 ebay manual & they were all connected! I have no Idea why the wire is commin thru the fire wall & just restin besides the friggin ecu!! I do think that I might have a broken wire, i have no cel on though I'm thinkin about checking all the wires that are hooked up to the ecu... but dunno how :( !! AHHHHHH!!!!! ALL JDM & NO VTEC MAKES LEO A BAD BOY!!!!!! Link to comment Share on other sites More sharing options...
DJB98LX Posted February 12, 2006 Share Posted February 12, 2006 Use a manual with the wiring diagrams, and a multimeter to pin test the wires. It'll take a long time, but it's worth it if you think there's a short/break! Link to comment Share on other sites More sharing options...
