fudge Posted August 11, 2005 Share Posted August 11, 2005 Hi all, in need of help! My car wont start and i'm not sure why! I have a 92 del sol VTEC. Its not the battery because thats been replaced recently and all the elctrics are fine and yes i do have fuel in the car. The engine is turning but its just not starting. I am guessing its the spark plugs. Anybody have any other ideas what else it could be or it it is the spark plugs, hpw do you change them? Link to comment Share on other sites More sharing options...
SolLesHonda Posted August 11, 2005 Share Posted August 11, 2005 92 sol vtec ... is it from japan .. cus i know they made them there but i didn't know the came dohc vtec ... or are you saying sohc vtec ... cus i know they didn't introduce the vtec sol until 94 ... unless im wrong, but i know thats in the U.S. ... don't know much about the honda del sols in japan, just that they had the trans-top models .. sunds like some type of spark is missing, try giving it a tune up ... plugs, plug wires, and maybe if needed, a new distributor cap .. plugs are easy to change, pull out the wires on the top of the block (there are 4), and put in a socket on them, or plug wrench if ya have one, and turn left, and pull em out .. do opposite for installation of new ones Link to comment Share on other sites More sharing options...
CleanGSR Posted August 11, 2005 Share Posted August 11, 2005 You're full of fudge. America got the del sol starting in 93 and Vtec model didn't come until 94. Overseas they got the del sol from 92-98 but none of the models were called Vtec. So......what kind of car do you have? It could also be fuel related. How many miles on the car and has the fuel filter ever been replaced? Link to comment Share on other sites More sharing options...
fudge Posted August 11, 2005 Author Share Posted August 11, 2005 Im from UK and my car is a DOHC VTEC. 74000 miles on the clock Link to comment Share on other sites More sharing options...
CleanGSR Posted August 11, 2005 Share Posted August 11, 2005 So it should be a VTI model then. With 74,000 miles you shouldn't be having any problems like this. I would check your plugs, plug wires and fuel filter. Those are all pretty inexpensive items, so see if any of those fixes the problem first. Link to comment Share on other sites More sharing options...
donnie Posted August 11, 2005 Share Posted August 11, 2005 theres a easy way to check look at your plugs...what color are they are they wet are they dry? then you will havea good idea what todo nexted Link to comment Share on other sites More sharing options...
Humphries Posted August 12, 2005 Share Posted August 12, 2005 just got bosch sparks and changed the oil.. my car starts awesome now. wowwww.. whats vti stand for.. i know they make vtis only in UK and England but i dont know what it means or how it is significant. Link to comment Share on other sites More sharing options...
CleanGSR Posted August 12, 2005 Share Posted August 12, 2005 VTI is there top model. It would be the equivalent to our Vtec Model. Link to comment Share on other sites More sharing options...
SexyH22 Posted August 12, 2005 Share Posted August 12, 2005 also check the cap and rotor. and make sure the pulg wires are pressed on tight, both onto the distributer cap, and onto each plug. maybe check the wire from the cap to the dizzy too. Link to comment Share on other sites More sharing options...
fudge Posted August 12, 2005 Author Share Posted August 12, 2005 Thanks all, now its the weekend I can have a good look at everything and figure out what it is. Link to comment Share on other sites More sharing options...
Sexyinwhite Posted August 12, 2005 Share Posted August 12, 2005 ya definitly check the wire coming from the coil going into the distributor thats what problem was a few days ago Link to comment Share on other sites More sharing options...
hellyeah!! Posted August 13, 2005 Share Posted August 13, 2005 did you figure anything out yet??? Link to comment Share on other sites More sharing options...
Brinkman Posted August 14, 2005 Share Posted August 14, 2005 i had this same problem it was my distributor.. the cap was cracked and water/crap leaked in.. it would sound like it was trying to start but it would never catch.. Link to comment Share on other sites More sharing options...
