civic94 Posted June 7, 2005 Share Posted June 7, 2005 my car bogs sometimes.. like it jerks when you are accelerating.. like not enough gas is being distributed.. its weird.. dont know why it does it.. someone help.. Link to comment Share on other sites More sharing options...
xxscaxx Posted June 7, 2005 Share Posted June 7, 2005 could be a couple of things distributor plugs wires fuel filter bad tank of gas ignition coil i had that too and i had a dirty gas tank and bad ignition coil. i had to get the tank dropped out and cleaned and then keep changing the fuel filter after every three tanks of gas, and couldnt bring it under 1/4 tank. and the ignition coil was bad too. Link to comment Share on other sites More sharing options...
redcoupe Posted June 8, 2005 Share Posted June 8, 2005 my car bogs sometimes.. like it jerks when you are accelerating.. like not enough gas is being distributed.. its weird.. dont know why it does it.. someone help.. Fuel-filter. Or check the plugs. Link to comment Share on other sites More sharing options...
SexyH22 Posted June 8, 2005 Share Posted June 8, 2005 or clogged injectors. Link to comment Share on other sites More sharing options...
dcletten Posted June 12, 2005 Share Posted June 12, 2005 doesnt sound like the coil, my coil just went out and it would just start up, then die right away and not restart for like 15 min, and then it finally just gave up and didnt start at all, but if it was running i didnt have a problem, only during startup Link to comment Share on other sites More sharing options...
XScarAudio Posted June 14, 2005 Share Posted June 14, 2005 check the air filter/air box first. no air - no start. start simple. Link to comment Share on other sites More sharing options...
