CleanGSR Posted June 6, 2005 Share Posted June 6, 2005 My car started making a clunking noise (not real loud, but noticable) when ever I take off or when I hit the brakes. It sounds like it is coming from the front of the car and it only clunks once when taking off or once when stopping. Actually any shift in momentum will make it clunk, like downshifting, accelerating, braking, etc. I have no idea what it is and the car doesn't drive any different than before the noise. Anybody have any ideas on what the problem could be? Link to comment Share on other sites More sharing options...
hellyeah!! Posted June 7, 2005 Share Posted June 7, 2005 have your drive axles checked or replaced. kind of sounds like one/both are going bad to me. Link to comment Share on other sites More sharing options...
xxscaxx Posted June 7, 2005 Share Posted June 7, 2005 yeah id say check the axles too. Link to comment Share on other sites More sharing options...
CleanGSR Posted June 7, 2005 Author Share Posted June 7, 2005 Great, I'm sure that will only cost a couple of bucks (j/k). I was hoping it would just be a bushing or something, but figured I wouldn't get that lucky. Link to comment Share on other sites More sharing options...
xxscaxx Posted June 7, 2005 Share Posted June 7, 2005 if you bring it to a shop, you can have one of the mechanics test drive it and they will tell you for sure if its the axles or not. my friend had a similar sound in his car and i told him it was the axles but his mom was bitchin b/c she wanted him to bring it to cherry tire for them to double check. the guy backed the car up, pulled back in the spot, and was like yep your axles are shot. Link to comment Share on other sites More sharing options...
CleanGSR Posted June 7, 2005 Author Share Posted June 7, 2005 I wonder if the CV axles are what I would need, cause nopionline has CV axles for 67.00 for each side. Link to comment Share on other sites More sharing options...
burplecrx90 Posted June 7, 2005 Share Posted June 7, 2005 check your front motor mount when they go out they make a noise like that they always go out i just tied a chain around mine and put a lock on it Link to comment Share on other sites More sharing options...
carib sol Posted June 10, 2005 Share Posted June 10, 2005 i would check your mounts 1st you can do it yourself, cheaper Link to comment Share on other sites More sharing options...
98integra Posted June 10, 2005 Share Posted June 10, 2005 i know this sounds stupid but the other day my wheel was loose and whenever i would break or hit the gas it clunked. but you prolly already figured it out Link to comment Share on other sites More sharing options...
hellyeah!! Posted June 11, 2005 Share Posted June 11, 2005 do you mean your lugnuts were loose or your bearings are screwed? Link to comment Share on other sites More sharing options...
98integra Posted June 13, 2005 Share Posted June 13, 2005 lugs Link to comment Share on other sites More sharing options...
CleanGSR Posted June 13, 2005 Author Share Posted June 13, 2005 Yeah, I already checked my lugnuts and motor mounts and it's not either of those. I took it by to a local mechanic that I trust and had him drive it and listen. He said that he doesn't think it is anything with the axles. He said it sounds like a bushing is going out and he could put it on his rack sometime to look for it. He told me if it gets worse then bring it back but if not that I shouldn't waste my money having him search for a semi-bad bushing. Link to comment Share on other sites More sharing options...
CleanGSR Posted June 16, 2005 Author Share Posted June 16, 2005 FIXED!!!!! Wierd one.... So I was taking off my front passenger wheel and noticed something. The lug nuts were not all the way down in the holes. They had caught the tiny little lip down inside the hole instead of going inside the lip. They were tightened down, just not centered so the wheel was slipping even though the lugnuts were tight. I took all the lugnuts out and retightened them making sure that they were centered and whoala....clunking sound is gone. Thanks for everyones advice.... I feel kinda stupid that it was something so simple. Link to comment Share on other sites More sharing options...
xxscaxx Posted June 16, 2005 Share Posted June 16, 2005 who cares man, at least u figured out the problem. +1 for you. Link to comment Share on other sites More sharing options...
