hondadiva Posted October 9, 2004 Share Posted October 9, 2004 My 1989 Honda Prelude 2.0si's sunroof leaks. The water doesn't drip in if you are driving around and it starts to rain, but if it sits parked while raining for awhile, when you start driving, and put the brakes on buckets of water dump in. Does any one know what that's all about? Link to comment Share on other sites More sharing options...
VR17 Posted October 9, 2004 Share Posted October 9, 2004 try some ducktape. some tellon.. or get an umbrella Link to comment Share on other sites More sharing options...
optional187 Posted October 10, 2004 Share Posted October 10, 2004 the drain holes may be clogged. my eclipse did this, only it was buckets of water it was more like a few drops and a small water stain on the moonroof cover. if you take a wire coat hanger and push it into the drain holes it should take care of the problem. on another note, since its such an old car your seals may have went bad. try replacing those if the drain hole thing doesn't work. Link to comment Share on other sites More sharing options...
hondadiva Posted October 15, 2004 Author Share Posted October 15, 2004 Thank you I will try that! Link to comment Share on other sites More sharing options...
nvision2nr Posted October 22, 2004 Share Posted October 22, 2004 i had the exact same problem, the sunroof doesnt actually seal at all its suposed to leak then drain throgh the 4 drain holes, first find the drain thats not flowing, and i used compressed air and squeezed black gunk out of the end of the hoze in the trunk wall Link to comment Share on other sites More sharing options...
