gonesurfing04 Posted June 5, 2004 Share Posted June 5, 2004 I have a 91 civic and was planing on swaping engines and was looking at this one...ZC DOHC..... and found it for 650 wit tranny and ecu, from the same place my friend got his engine. Well I want to know if there's any major modifications I need to do like change the shift linkage or the axles or anything like that? Or if the engine will just fit right in to the car as it is? Any help would be great. Thanks. This is the engine Link to comment Share on other sites More sharing options...
stuckmofo Posted June 5, 2004 Share Posted June 5, 2004 I have a 91 civic and was planing on swaping engines and was looking at this one...ZC DOHC..... and found it for 650 wit tranny and ecu, from the same place my friend got his engine. Well I want to know if there's any major modifications I need to do like change the shift linkage or the axles or anything like that? Or if the engine will just fit right in to the car as it is? Any help would be great. Thanks.This is the engine just make sure you get ALL the parts you need to do the swap all at once! hmotorsonline.com Link to comment Share on other sites More sharing options...
..SSR.. Posted June 6, 2004 Share Posted June 6, 2004 There aren't a lot of parts for ZC's. Save up another hundred bucks and get a D16Y8, much much better engine. Link to comment Share on other sites More sharing options...
CRG7 Posted June 7, 2004 Share Posted June 7, 2004 There aren't a lot of parts for ZC's. Save up another hundred bucks and get a D16Y8, much much better engine. there aren't a lot of parts for zc's because 88-89 integra and 88-91 civic/crx parts can be used on them. here's a good page for information that you should bookmark if you plan to do the zc swap: http://www.quickhonda.net/zc3.htm Link to comment Share on other sites More sharing options...
BigBirdSucks Posted June 8, 2004 Share Posted June 8, 2004 just make sure you get ALL the parts you need to do the swap all at once! hmotorsonline.com eh, all the parts swap over to the ZC. if you have a D16A6, I'll trade you engines. Link to comment Share on other sites More sharing options...
civicracer388 Posted June 10, 2004 Share Posted June 10, 2004 I'd save up for a different engine. D16 SOHC VTEC engines go in cleanly and make the same amount of power as a ZC with the comfort of having more available parts. My two cents. Link to comment Share on other sites More sharing options...
cagepoet1805 Posted June 22, 2004 Share Posted June 22, 2004 everyone i know that did the swap said they would have been better off with the d16y8 because you pay sooo much for any sensor that goes wrong. the initial cost may be nice, but in the end you will probobly pay more for the zc and it still wont keep up with the y8. Link to comment Share on other sites More sharing options...
EFHatchTuner Posted September 22, 2004 Share Posted September 22, 2004 ZC motors are small motors. You can swap out the stock ZC tranny with a tranny off of a D16Z6 if you wanted to. Your stock axles and shift linkage should go with it perfectly. Id buy the SOHC ZC swap instead, its VTEC. I hear the dual cams are strong as hell though, boost goes hand in hand with them. Link to comment Share on other sites More sharing options...
