mike5327 Posted January 27, 2004 Share Posted January 27, 2004 I have a 98 accord and I was wondering which engine would be easier to swap in, the H22a from a 97 or up prelude or an f20 Link to comment Share on other sites More sharing options...
LeafBoy Posted January 27, 2004 Share Posted January 27, 2004 who am i to say anything cause im noob, but from what i read i would go with a H22 engine Link to comment Share on other sites More sharing options...
..SSR.. Posted January 27, 2004 Share Posted January 27, 2004 H22 and high compression pistons if you want torque down low or the F20 and cams if you want power up high. Link to comment Share on other sites More sharing options...
mike5327 Posted January 27, 2004 Author Share Posted January 27, 2004 Which one would be less work to swap in? Link to comment Share on other sites More sharing options...
joecollins2 Posted January 28, 2004 Share Posted January 28, 2004 Less work? F20 Bigger payoff: (in my opinion) H22 Link to comment Share on other sites More sharing options...
..SSR.. Posted January 28, 2004 Share Posted January 28, 2004 They are both the same to swap in. The only difference is engine internals and the valve cover. Link to comment Share on other sites More sharing options...
mike5327 Posted January 29, 2004 Author Share Posted January 29, 2004 Does the H22a use factory mounts on my 98 accord because I have heard many different things. Link to comment Share on other sites More sharing options...
..SSR.. Posted January 29, 2004 Share Posted January 29, 2004 No, you need a mount kit. Link to comment Share on other sites More sharing options...
mike5327 Posted January 29, 2004 Author Share Posted January 29, 2004 So all I need to do is buy a mount kit and an OBD1 to OBD2 harness and Im set? Is it an easy install? Link to comment Share on other sites More sharing options...
mike5327 Posted January 29, 2004 Author Share Posted January 29, 2004 Is there any engine that will use my factory mounts? Link to comment Share on other sites More sharing options...
..SSR.. Posted January 29, 2004 Share Posted January 29, 2004 So all I need to do is buy a mount kit and an OBD1 to OBD2 harness and Im set? Is it an easy install? No, it isn't a piece of cake. Link to comment Share on other sites More sharing options...
mike5327 Posted January 29, 2004 Author Share Posted January 29, 2004 Tell me a site where I can get a walkthrough. Are there any engines that use my factory mounts? Link to comment Share on other sites More sharing options...
carta79 Posted January 29, 2004 Share Posted January 29, 2004 I'd look into doing a whole lot of research if I were you. Join up with Hondaswap.com and go through some swap articles. Link to comment Share on other sites More sharing options...
joecollins2 Posted January 29, 2004 Share Posted January 29, 2004 Which one would be less work to swap in? Read this Here's the chart you need for the conversion just follow the column's 1.ECU PIN 2.Prelude '97 3.Accord '96 4.93 Prelude 1. 2. 3. 4. A1 INJ4 INJ4 a1 A2 INJ3 INJ3 a2 A3 INJ2 INJ2 a3 A4 INJ1 INJ1 a5 A5 SO2SHTC SO2SHTC x A6 PO2SHTC PO2SHTC a6 A7 ESOL ESOL a11 A8 VTS VTS a4 A9 LG1 LG1 a26 A10 PG1 PG1 a23 A11 IGP1 IGP1 a25 A12 IACV IACV a9 A15 PCS PCS a20 A16 FLR FLR a7 a8 A17 ACC ACC a15 A18 MIL MIL a13 A19 ALTC ALTC a16 A20 ICM ICM a21 a22 A22 LG2 LG2 b2 A23 PG2 PG2 a24 A24 IGP2 IGP2 b1 A25 ICSOL IARSOL a19 A26 IABSOL x a17 A27 FANC FANC a12 A28 2WBS 2WBS x A29 VSV VSV x C1 VREF C2 CKPP CKPP b15 C3 TDCP TDCP b13 C4 CYPP CYPP b11 C5 ACS ACS b5 C6 STS STS b9 C7 SCS SCS d4 C8 K-LINE K-LINE x C10 VBU VBU d1 C12 CKPM CKPM b16 C13 TDCM TDCM b14 C14 CYPM CYPM b12 C15 VTM x d6 C16 PSPSW PSPSW b8 C17 ALTF ALTF d9 C18 VSS VSS b10 D1 TPS TPS d11 D2 ECT ECT d13 D3 MAP MAP d17 D4 VCC1 VCC1 d19 D5 BKSW BKSW d2 D6 KS x d3 D7 PHO2S PHO2S d14 D8 IAT IAT d15 D9 EGRL EGRL d12 D10 VCC2 VCC2 d20 D11 SG2 SG2 d22 D12 SG1 SG1 d21 D13 x SHO2SG x D14 SHO2S SHO2S x D15 PTANK PTANK x D16 EL EL d10 Link to comment Share on other sites More sharing options...
mike5327 Posted January 29, 2004 Author Share Posted January 29, 2004 Its different for a 98 accord. That article is for a 96 accord, thats why that swap is so easy. The H22a does not use the 98 accord factory mounts. I just want to know what the easiest swap for me would be. Link to comment Share on other sites More sharing options...
joecollins2 Posted January 29, 2004 Share Posted January 29, 2004 Sorry I guess I didn't pay attention to that. Link to comment Share on other sites More sharing options...
mike5327 Posted January 30, 2004 Author Share Posted January 30, 2004 I just want to know what the easiest swap for me would be. Link to comment Share on other sites More sharing options...
..SSR.. Posted January 30, 2004 Share Posted January 30, 2004 The only swaps you can do are H22A or F20B. Link to comment Share on other sites More sharing options...
dd_biggy Posted January 30, 2004 Share Posted January 30, 2004 still didn't answer his question... Link to comment Share on other sites More sharing options...
mike5327 Posted January 30, 2004 Author Share Posted January 30, 2004 LOL Im glad someone finally realizes my pain. Link to comment Share on other sites More sharing options...
optional187 Posted January 31, 2004 Share Posted January 31, 2004 i think your question was answered on the first page... Link to comment Share on other sites More sharing options...
mike5327 Posted January 31, 2004 Author Share Posted January 31, 2004 If it was answered then why dont you show me where because as I see it, there is no answer Link to comment Share on other sites More sharing options...
optional187 Posted January 31, 2004 Share Posted January 31, 2004 Less work? F20 Bigger payoff: (in my opinion) H22 They are both the same to swap in. The only difference is engine internals and the valve cover. No, you need a mount kit. what else do you want to know? ask directly (number them if you want) and i'm sure ssr can supply you with the answers you're looking for. Link to comment Share on other sites More sharing options...
..SSR.. Posted January 31, 2004 Share Posted January 31, 2004 1. Any swap won't be easy. 2. There is no easiest swap, like I said, both engines are exactly the same other than internals and valve cover. 3. No, it doesn't use stock mounts. 4. www.doafrackingsearch.com Link to comment Share on other sites More sharing options...
mike5327 Posted January 31, 2004 Author Share Posted January 31, 2004 Well I figured this forum was a place where you ask questions to get answers. But I guess I was wrong. Link to comment Share on other sites More sharing options...
