08 Honda Accord sputter when take off
Jessthemess
Posted
I have a Honda Accord 08 and I have changed fuel filter,spark plugs,timing belt changed oil and got fuel cleaner and it still does it I have no lights on except tire sensor what could cause this I even started putting premium gas in it and Still sputters I even  changed front and back brakes and hardware any ideas?
Posted
Air filter maybe.. 1st, have the car checked for computer codes, even if the trouble light is not lit up. Sounds like it's starving for fuel or has a bad sensor or clog someplace in the system, and not all problems will set of the check engine light. Post back if you find any codes and we can go from there.
One post I read said this "Crank Angle Sensor replacement needed, most likely" but that's just a guess.. in general you are looking at vacuum leaks, air sensors, clogged fuel injector, long list of combustion and ignition timing problems that can cause misfiring.
Here is a good article on the problem with Hondas:
https://www.yourmechanic.com/estimates/honda/fit/engine-is-sputtering-inspection   (they advertise mobile mechanics that will diagnose for you)
An incomplete combustion in the engine will cause a sputter as can the ignition system. The fuel system, such as a blocked fuel injector may also cause the vehicle to sputter. While a sputtering engine may not seem like a major issue, it is a symptom of a bigger problem that will not self-correct and will eventually result in a much more expensive repair. The source of the sputter should be investigated and repaired as soon as possible.
How this system works:
A sputtering engine can have its root cause located in a number of different systems. Here are two of the more common ones, the exhaust and fuel system.
The exhaust system collects exhaust gases from the cylinder head via the exhaust manifold, which acts as a funnel diverting exhaust gases away from the cylinders. The gases are then released through the front pipe where they travel to the catalytic converter. The catalytic converter removes the harmful elements of the gases such as carbon monoxide and hydrogen monoxide, converting them into inert gases.
The gases exit the catalytic converter into the muffler, which reduces the noise levels of the engine, and finally the exhaust fumes exit the vehicle at the tail pipe.
The fuel system is responsible for storing and supplying fuel to the car to drive the engine. Fuel is mixed with air, atomized and vaporized. This happens in the engine intake system. This mixture is then compressed in the engine cylinder and then ignited which produces the energy which moves the pistons.
Common reasons for this to happen:
  • Leak in Exhaust Manifold: A leak in the exhaust manifold, which collects exhaust gases, can cause the engine to sputter or run unevenly. This condition can also cause the Check Engine light to trigger as well as present increased engine noise and poor performance from the engine. A cracked or leaking exhaust manifold can create dangerous driving condition as the escaping hot gases can melt nearby plastic components. It can also lead to exhaust fumes making their way into the car cabin.
  • Worn Seals or Gaskets: There are a number of gaskets and seals in the exhaust system and if any of them are failing it can create a rough or sputtering engine. Gaskets and seals wear down over time and will eventually have to be replaced. Failing to do this in a timely manner can damage the exhaust manifold which is a much more expensive repair.
  • Failing Catalytic Converter: If the engine is sputtering, running rough and has a smell of rotten eggs it is probably due to a failing catalytic converter. In most cases, the Check Engine light will trigger as well. When a converter starts to fail, it isn’t able to burn off the hydrocarbons in the exhaust, and is no longer breaking down the sulfur created by the engine. This leads to the strong rotten egg smell. Eventually the car will not start at all as the catalytic converter becomes totally blocked.
  • Malfunctioning Oxygen Sensors: Oxygen sensors measure how rich or lean the exhaust gases are when they leave the vehicles combustion chamber. The vehicle computer uses this information to adjust the amount of fuel entering the engine. A dirty or failing sensor puts too much or too little fuel into the engine causing it to run rough or sputter. Oxygen sensors must be replaced on a regular basis.
  • Dirty Fuel Injectors: Fuel injectors spray fuel into the cylinders. It is then mixed with air and ignited. Fuel injector nozzles can become clogged over time, which can lead to a sputtering engine, slow acceleration and the car not having enough power. Fuel injectors can be cleaned if the problem is caught early, but as the conditions worsens, the injectors may have to be replaced.
  • Bad or Dirty Spark Plugs: Spark plugs are responsible for igniting the fuel in the combustion chamber. If they are not working correctly or are dirty they don’t ignite the fuel cleanly and the car can misfire or sputter. The plugs will need to be replaced or cleaned.
  • Dirty Mass Airflow Sensor: The mass airflow sensor measures the amount of air that is entering the fuel injection system. It sends that information to the vehicle computer, which then delivers the proper amount of fuel to the combustion chamber. A dirty mass airflow sensor will send the wrong information the computer resulting in a rough running or sputtering engine.
  • Vacuum Leak: A leak in the vacuum system can lead to a sputtering or rough running engine. As the problem progresses the vehicle can hesitate or stall when accelerating.
