SIR_VTEC Posted January 22, 2004 Share Posted January 22, 2004 Anyones ZC run rich? And if so how did you fix it if you did? Link to comment Share on other sites More sharing options...
BuddySol Posted January 23, 2004 Share Posted January 23, 2004 what was the question again? i couldn't stop staring at your avatar...hahaha Link to comment Share on other sites More sharing options...
optional187 Posted January 23, 2004 Share Posted January 23, 2004 the avatar is going too slow for my a.d.d., i'll have to watch the rest of it tomorrow at school. while we're off topic...the picture in your sig doesn't work buddysol. not the one of the sol, but the one next to it. anyways, wasn't there another thread about this a long time ago? was it you sir vtec? mike might be able to help, he used to have a zc crx Link to comment Share on other sites More sharing options...
BigBirdSucks Posted January 23, 2004 Share Posted January 23, 2004 I have a civic with a ZC. what ECU are you using? what are your mods? Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 23, 2004 Author Share Posted January 23, 2004 BUddy: yea the avatar is tempting to watch ...thats why i got the thing haha but yea its pretty funny. Optional: yea i think i did and i didnt get too many answers. Bigbird: Well i have a 89 integra DOHC non vtec 1.6L and have a 91 SI ECU....well i was told that would be the best set up for the motor...but ever since ive had the swap it was running rich...what they told me when i swapped the motor since its a JDM motor its always going to run rich....i thought it wasnt true...ive seen ZC swaps in DX models and they run perfectly fine...but i think they were USDM not JDM..but i dunno let me know what you guys think? MODS: Intake, headers, 2.5" straight pipe exhaust, also there is a fuel pressure hooked up im not sure what its running at in somewhere in the 20's that i know of at least...like 25-27 range...but yea thats about all the mods that are done. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted January 24, 2004 Share Posted January 24, 2004 how do you know it's running rich? do you not have a catalytic converter? Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 26, 2004 Author Share Posted January 26, 2004 put it this way my spark plugs are charcoal after a month and i change it that frequently and also i dont not have a cat...i have a 2.5 inch st8 pipe exhaust...but im pretty sure thats not the reason. Link to comment Share on other sites More sharing options...
EGRacer Posted January 28, 2004 Share Posted January 28, 2004 hmmmmmmmmm.....interesting. my zc never ran rich and i had a teg ls 1.8 ecu. never had a problem at all. hmmmmm will have to consult with a few informants on this one Link to comment Share on other sites More sharing options...
EGRacer Posted January 28, 2004 Share Posted January 28, 2004 let me suggest rising up to a higher heat range plug expecially in a colder climate and also check your egr valve if motor still has one. sounds like raw fuel is getting to combustion chamber w/o being burned. also check for vacuum leaks. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 28, 2004 Author Share Posted January 28, 2004 from what i was told i should use a 91 SI civic ECu because thats the best for my car...so i dunno...let me know if you find out anything different...was ur motor JDM or USDM? Also did you have the DOHC ZC or SOHC ZC? and what year was ur ZC...i knew it shouldnt runt rich, its been running like that for sometime now so i dunno...let me know asap what may be the problem...also was ur check engine light on when you swapped motorS? Link to comment Share on other sites More sharing options...
EGRacer Posted January 28, 2004 Share Posted January 28, 2004 my ZC engine was DOHC. i used a '89 or '90 teg ls ecu. its was JDM ZC. the ZC was like a '91 or '92 Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 29, 2004 Author Share Posted January 29, 2004 so you used a LS ecu ....i might just have to get that instead...but would that even matter in a DX swap? what kinda civic did you have what model? Link to comment Share on other sites More sharing options...
EGRacer Posted January 29, 2004 Share Posted January 29, 2004 i had a dx crx like u. i wanted a hf but couldnt find one for cheap enough. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted January 29, 2004 Author Share Posted January 29, 2004 really? hmm, i mean yea i dont understand why my check engine light would be on because all my other guys have swaps and JDM at that and no Check engine light.....hmmm.well i'll try switching ECU's...and i'll update you. Link to comment Share on other sites More sharing options...
