Humphries Posted January 30, 2013 Share Posted January 30, 2013 Starting off the year right and back into a honda... well, it's a project for now, but should be running in about 2 months by ImportAlliance Atlanta. In this build I'll be doing a D16z6 full engine rebuild, s20 transmission overhaul, wire tucking and re-looming dash and engine harnesses, and tucking headlight harnesses. Installing Energy suspension bushing kit, all new wheel bearings, disc brake conversion, and engine bay repaint. Purchased this car from one of my best friends who bought a vr6 jetta, with hopes to make this his project. He (I) removed the engine and transmission (b16a2) and he tore it apart to rebuild for turbo. It sat for 4 months until he just wanted to part it out and sell the shell to buy wheels and suspension for his jetta. He gave me an awesome deal on the shell (full interior, rolling chassis, megan coilovers) and i couldnt pass it up. I will be over his house working on it this weekend since my driveway is blocked by a giant storage unit due to renovating and will update with pics when something's worth showing. Link to comment Share on other sites More sharing options...
Humphries Posted January 30, 2013 Author Share Posted January 30, 2013 computer froze.. delete one please? Link to comment Share on other sites More sharing options...
Rayden Nery Posted January 30, 2013 Share Posted January 30, 2013 nice car Link to comment Share on other sites More sharing options...
Humphries Posted February 3, 2013 Author Share Posted February 3, 2013 Just bought a b16a2 for 350... Builds coming along. I'll post pic soon Link to comment Share on other sites More sharing options...
Humphries Posted February 4, 2013 Author Share Posted February 4, 2013 Purchased: B16a2 Hasport mounts and t bracket Rear disc swap from integra Function&form rear lower control arms OEM hood bra/mask Coming up: Supertech flat face valves Super tech dual valve springs Super tech retainers Keepers Oem valve guides Gasket kit Piston rings Hone block Acl bearings Heat tanked head, possibly 3avj Rmf header Custom exhaust Steering rack rebuild kit Battery Engine bay paint job B16 transmission Link to comment Share on other sites More sharing options...
Humphries Posted February 7, 2013 Author Share Posted February 7, 2013 this is what has become of my bedroom Link to comment Share on other sites More sharing options...
..SSR.. Posted February 8, 2013 Share Posted February 8, 2013 All your doing with the Supertech springs with stock cams is robbing power. Ditch the ES bushings and Megan coilovers. Bore the block and get new pistons. Link to comment Share on other sites More sharing options...
James Matteu Posted February 8, 2013 Share Posted February 8, 2013 Put that stuff in your garage. Link to comment Share on other sites More sharing options...
Humphries Posted February 12, 2013 Author Share Posted February 12, 2013 I am not doing supertech anything anymore. ordered acl bearings, thrust washers, npr rings, and full seal and gasket kit for entire engine, rywire b series harness, and gsr transmission lapped OEM valves, new seals, putting it all back to stock. my garage is full of my motorcycle build and hardwood flooring. I didn't want to lose anything so I put it in my room to organize my workstation. Link to comment Share on other sites More sharing options...
Humphries Posted February 12, 2013 Author Share Posted February 12, 2013 this is all on Honda-tech also... I update it more often Link to comment Share on other sites More sharing options...
Humphries Posted February 13, 2013 Author Share Posted February 13, 2013 got the gsr transmission and pulled the case off and when I removed the shafts, the 3-4 shift fork had excessive play and I believe there is a bushing that may be worn out. I looked on majestic at a b16 transmission trying to see if there was a part number for the little bushing that seems to be the problem but couldn't find anything Link to comment Share on other sites More sharing options...
James Matteu Posted February 13, 2013 Share Posted February 13, 2013 They sometimes include bushings in a set if there are several sizes to choose from. Link to comment Share on other sites More sharing options...
Humphries Posted February 13, 2013 Author Share Posted February 13, 2013 Where do you get an assortment of aluminum bushings? Link to comment Share on other sites More sharing options...
Rick B. Posted February 20, 2013 Share Posted February 20, 2013 how exciting. Link to comment Share on other sites More sharing options...
Humphries Posted February 23, 2013 Author Share Posted February 23, 2013 yeah. thuper exciting.. Link to comment Share on other sites More sharing options...
