CivicSam Posted October 26, 2003 Share Posted October 26, 2003 When installing an air intake what processes are involved? Is welding necessary, or is usually a straight bolt on. Is it difficult to remove your air filter housing? How long does the process take? Link to comment Share on other sites More sharing options...
optional187 Posted October 26, 2003 Share Posted October 26, 2003 it'll take you 30 minutes if you don't know what you're doing. no welding. straight bolt-on. if you remove your resonator then you'll have to remove your front bumper, which isn't hard at all either. Link to comment Share on other sites More sharing options...
..SSR.. Posted October 26, 2003 Share Posted October 26, 2003 Read the directions, no welding required. Link to comment Share on other sites More sharing options...
CivicSam Posted October 27, 2003 Author Share Posted October 27, 2003 haven't purchased yet, doing research..... ok, pros and cons of cold air intake over "regular" Link to comment Share on other sites More sharing options...
optional187 Posted October 27, 2003 Share Posted October 27, 2003 and by regular you mean short ram? or stock? Link to comment Share on other sites More sharing options...
CivicSam Posted October 27, 2003 Author Share Posted October 27, 2003 short ram.... but now that you mention it, stock too if you know. Link to comment Share on other sites More sharing options...
..SSR.. Posted October 27, 2003 Share Posted October 27, 2003 Stock, flows more air Short ram, cooler intake temp. Link to comment Share on other sites More sharing options...
CivicSam Posted October 27, 2003 Author Share Posted October 27, 2003 ok, time to sound stupid... ideally I want more oxygen going into the engine to increase the size of explosions and make the engine run more efficiently, so then wouldn't stock be ideal? If I"m talking out of my butt, let me know. Oh, and after you let me know, correct my logic. Thanks. Link to comment Share on other sites More sharing options...
..SSR.. Posted October 28, 2003 Share Posted October 28, 2003 ok, time to sound stupid... ideally I want more oxygen going into the engine to increase the size of explosions and make the engine run more efficiently, so then wouldn't stock be ideal? If I"m talking out of my butt, let me know. Oh, and after you let me know, correct my logic. Thanks. 1. You will only flow as much air as your head will allow (cams/valvetrain included in head). 2. Explosions = bad. Burning = good. 3. You don't want the gas to explode, you want it to burn. Link to comment Share on other sites More sharing options...
CivicSam Posted October 28, 2003 Author Share Posted October 28, 2003 Thanks. Explosions bad... got it. SO then if more air is good, wouldn't a stock model be best? Link to comment Share on other sites More sharing options...
optional187 Posted October 28, 2003 Share Posted October 28, 2003 colder air is better than warmer air. i had a short ram on my civic and it did fine...doubt it gave me very much hp though. from what i've heard from people around here injen cold air intake's give the most gain. Link to comment Share on other sites More sharing options...
..SSR.. Posted October 28, 2003 Share Posted October 28, 2003 A stock intake tubing and box is a mess of mazes and ridges. That restricts the flow and it doesn't take in cold air. An aftermarket CAI is smooth and takes in cold air. Hence flowing better and more power. Comptech Icebox makes more power over Injen. Link to comment Share on other sites More sharing options...
