b16a1integra Posted January 15, 2012 Share Posted January 15, 2012 so i got my motor in and all wired up starts ight up no CEL or anything. The passenger side axle popped right in, all joints matched up lower ball joint ect. so the passenger side hub was easy as can be to put together. but the driver side axle slid right on to the midshaft and the hub, but i cant seem to get the lower balljoint into the lower control arm idk why it wont go in. and my car is a 93 civic lx and its a 2nd gen b16a im using the axles that the swap came with. please help!!!! Link to comment Share on other sites More sharing options...
Raley Posted January 16, 2012 Share Posted January 16, 2012 you don't have it all the way in the intermediate shaft.. you will wanna coat that sucker in high temp grease... or the intermediate shaft isn't bolted in properly... where that goes into the motor, you should put alil grease on it but not to much... axle to midshaft, coat that bitch up! Link to comment Share on other sites More sharing options...
