almightyaccord Posted October 16, 2003 Share Posted October 16, 2003 Ok so here is what i want to do!! I want to go to the junk yard and get two extra 9006(low beams) and add them to my bumper lights(1992 honda accord 4dr SE) so its like having fog lights with lots of extra light. But what my question is to make this easy and clean can i just tap into the same two wires that go into my 9006 socket(that is already in the stock headlight unit). Like also will this be safe or will it work for a little while and then burn out or what. Also if i cant do that then what can i do to make this happen b/c i really want to do it. even if i have to run new wires and if i have to install new wires can i just run it like a regular setup........of having a clean ground, and a wire to the battery(with a fuse of course) and a switch to my dash. or what??. Any info or how-to pages will help alot. well that all thanx. Link to comment Share on other sites More sharing options...
optional187 Posted October 16, 2003 Share Posted October 16, 2003 i doubt you can find an exact how-to on this...but you should just install them like they are regular fog lights (clean ground, fuse, and switch on the dash) in my opinion...wiring them to the regular headlights doesn't sound like a good idea. do you just want bulbs, or do you want the whole assembly? Link to comment Share on other sites More sharing options...
..SSR.. Posted October 16, 2003 Share Posted October 16, 2003 Thats retarded. You don't need bright fog lights. All they do is light up the ground in front of your car. Having bright fog lights won't do jack except waste money. Link to comment Share on other sites More sharing options...
optional187 Posted October 17, 2003 Share Posted October 17, 2003 not to mention look pretty stupid (if you want to get the whole assembly) and blind other drivers... Link to comment Share on other sites More sharing options...
