HunterMilesLeggett Posted May 17, 2011 Share Posted May 17, 2011 i put the 92 1.8 ls integra motor dohc in my 90 honda hatch. the stock motor is a 1.5 so i got two of the short stock cv axles and changed the cup that goes into motor so it'll fit stock hub, but 1.8 motor. the motor mounts arent all tightened down, and the ball joint is not even an inch from going back into the hole, but it wont go in. what could be the cause of this. i need help badly. thanks Link to comment Share on other sites More sharing options...
Raley Posted May 17, 2011 Share Posted May 17, 2011 d-series axles and b-series axles are a ton different... Link to comment Share on other sites More sharing options...
HunterMilesLeggett Posted May 17, 2011 Author Share Posted May 17, 2011 what do i need to do then? i know this has been done before. i just dont know anyone whos done it. Link to comment Share on other sites More sharing options...
Raley Posted May 17, 2011 Share Posted May 17, 2011 walk to autozone, get b-series axles, walk home, install. Link to comment Share on other sites More sharing options...
Raley Posted May 18, 2011 Share Posted May 18, 2011 The b18 axles will fit your stock hubs. Nothing needs to be taken apart. Link to comment Share on other sites More sharing options...
HunterMilesLeggett Posted May 21, 2011 Author Share Posted May 21, 2011 my hub is 23 spline. the b18 alll the have for it is 26. Link to comment Share on other sites More sharing options...
Raley Posted May 22, 2011 Share Posted May 22, 2011 then you sir dont have stock spindles... Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted May 25, 2011 Share Posted May 25, 2011 well then get integra axles and integra spindles... i didnt run into that problem since the del sol and integra are the same chassis Link to comment Share on other sites More sharing options...
