bmfs001 Posted April 13, 2011 Share Posted April 13, 2011 I have a1997 civic ex with a 1994 d16z6. I can't get any spark. It has new distributor,wires everything.apparently the car was in some sort of accident. I didn't know it wen I bought it. Does any one know anything I can try? Link to comment Share on other sites More sharing options...
Raley Posted April 13, 2011 Share Posted April 13, 2011 Bad ground Link to comment Share on other sites More sharing options...
Xeryon Posted April 13, 2011 Share Posted April 13, 2011 the number one question is: has it ever ran since being swapped? Link to comment Share on other sites More sharing options...
bmfs001 Posted April 13, 2011 Author Share Posted April 13, 2011 No And im a newb Link to comment Share on other sites More sharing options...
Xeryon Posted April 13, 2011 Share Posted April 13, 2011 did you swap it? need to find out what ecu you are using Link to comment Share on other sites More sharing options...
bmfs001 Posted April 13, 2011 Author Share Posted April 13, 2011 No fuel either. Changed ecus changed relays checked fuses Checked main grounds and harness. Link to comment Share on other sites More sharing options...
Xeryon Posted April 13, 2011 Share Posted April 13, 2011 changed ecu doesn't tell me what ecu you are using Link to comment Share on other sites More sharing options...
bmfs001 Posted April 13, 2011 Author Share Posted April 13, 2011 Oh sorry. P2p Link to comment Share on other sites More sharing options...
bmfs001 Posted April 13, 2011 Author Share Posted April 13, 2011 Me and a friend swapped it Link to comment Share on other sites More sharing options...
Xeryon Posted April 13, 2011 Share Posted April 13, 2011 that's what i expected. lets start by getting the right ecu. you have an obd2 ecu trying to run an obd1 engine. get a p28 ecu (your car is manual right?) and the appropriate conversion harness (because the connector on your p2p isn't the same as the connector on the p28) and then we might stand a chance at helping you to get this running. Link to comment Share on other sites More sharing options...
bmfs001 Posted April 13, 2011 Author Share Posted April 13, 2011 Ok I ordered the harness and im getting distributor jumper today. Link to comment Share on other sites More sharing options...
bmfs001 Posted April 22, 2011 Author Share Posted April 22, 2011 I got jumper it sounded like it was gonna start but Nope. Fuel pump not pumping either Link to comment Share on other sites More sharing options...
Raley Posted April 22, 2011 Share Posted April 22, 2011 Fuel pump is main relay, wiring or pump. Link to comment Share on other sites More sharing options...
bmfs001 Posted April 22, 2011 Author Share Posted April 22, 2011 Changed relays pumps brand new Link to comment Share on other sites More sharing options...
Raley Posted April 22, 2011 Share Posted April 22, 2011 a short in a wire? Link to comment Share on other sites More sharing options...
bmfs001 Posted April 22, 2011 Author Share Posted April 22, 2011 frack idk im lost Link to comment Share on other sites More sharing options...
bmfs001 Posted April 26, 2011 Author Share Posted April 26, 2011 Im not getting power to my injectors fuel pump and stool no spark Link to comment Share on other sites More sharing options...
Xeryon Posted April 26, 2011 Share Posted April 26, 2011 What are you getting power to? On anything I have ever worked on when you got no spark, no fuel and the battery and connections are good (everything else has power) - it's the ecu Link to comment Share on other sites More sharing options...
bmfs001 Posted April 26, 2011 Author Share Posted April 26, 2011 Swapped ecus stiill nothing Link to comment Share on other sites More sharing options...
Xeryon Posted April 26, 2011 Share Posted April 26, 2011 so everything else gets power? accessories and dash and lights and crap? if you get dash lights are you getting a CEL? Link to comment Share on other sites More sharing options...
bmfs001 Posted April 26, 2011 Author Share Posted April 26, 2011 What's a cel?checkengine light? NoIm not I got lights. No power to injectors. Link to comment Share on other sites More sharing options...
