MarkyXJr Posted December 16, 2010 Share Posted December 16, 2010 Ok i had just finished rebuilding my enigne from the ground up using mostly stock parts the day i finished putting it back in like a week ago i was able to fire her right up and drive her awhile with the only problem being a rough idle and sumtimes stalling out when i come to a complete stop the rmps would just not stay up. But anyways i replaced the map sensor cause thats what i thought it was and since then i havent been able to get he motor to start im getting gas and spark but only on cyl 2 and 3 ater trying to start it i pulled the plugs and 1 and 4 where soaking with gas, i have compression in all cyls i just cant get cyl 1 and 4 to get spark and fire, like i said i had it running b4 i just cant figure out why is would decide to now not start. i put the old map senor on thinking that the only thing i changed and same thing was happening, if anyone got any ideas i would like to hear them, thank you in advance = ) Link to comment Share on other sites More sharing options...
Xeryon Posted December 16, 2010 Share Posted December 16, 2010 You need to test your distributor if you are not getting spark to all four. Link to comment Share on other sites More sharing options...
Raley Posted December 16, 2010 Share Posted December 16, 2010 cap and rotor or timing... Link to comment Share on other sites More sharing options...
