aroyale15 Posted November 18, 2010 Share Posted November 18, 2010 Does the check engine light automatically disappear once the problem is fixed or do I need to OBD scanner to clear it? Link to comment Share on other sites More sharing options...
Raley Posted November 18, 2010 Share Posted November 18, 2010 disconnect battery for about 30 seconds or pull ecu fuse... also helps to know car (thats for the older ones) Link to comment Share on other sites More sharing options...
Escape-performance Posted November 22, 2010 Share Posted November 22, 2010 Some cars work best if you disconnect both battery cables and hold them together for 20seconds. Link to comment Share on other sites More sharing options...
mudweiser99 Posted December 15, 2010 Share Posted December 15, 2010 no it will stay forever cuz the problem is the fact that u drive a honda Link to comment Share on other sites More sharing options...
Tubbith Posted December 15, 2010 Share Posted December 15, 2010 97 or newer will more than likely need to have a scanner remove the CEL. Older than that, unhooking the battery might remove it. Link to comment Share on other sites More sharing options...
