jdmben Posted October 25, 2010 Posted October 25, 2010 if i have 174k miles on my d16z6 will i be safe pushing 5-7 psi with my stock internals?
SpeedDemon Posted October 25, 2010 Posted October 25, 2010 if you engine does not burn any oil or smoke and is in healthy running condition then yes. but with high miles i highly advise a rebuild before boost. its just that extra piece of mind. if you do rebuild, check out d-series.org. FJ distributors sells a piston/rod combo that is under $400. along with a good tune, clutch, and some other things you can easily see 280whp
