car trouble
ross615
Posted
ok i just got my car running good my timing was a little off but sometimes when i pull into a road or pull up to a stop sign my car will die mostly it does it when i down shift what could it be im thinking vacum leak?
Posted
For the most part a vacuum leak will make your idle go up never down......how off is your timing and what are you drivin?
Posted
it was off just a tooth but i fixed that but now it wants to die or sometimes it bogs down and my intake makes a sound and i can give it gas but it wont do anything then if i keep puching the gas pedal it will go and also sometimes when i try to start it back after it dies my fuel pump wont kick in? its a 93 integra b18a1
Posted
Did you check to make sure your intake filter is good and nothing is blocking air from getting to your motor.
Posted
yes filter is like new
Posted
ive noticed it does it more when i get lower on gas like a 1/4 of a tank
Posted
maybe your getting fuel cut or if not fuel pump is problably cutting off, i had the same problem
so i probally need to try a new puel pump?
Posted
yea try one, just get a walbro 255 and you'll be good its worth it. but check everything first. i changed mine and its great
Posted
ok will do thank man
  • 5 months later...
Posted
i had the same problem with my 91 teg and it was the damn catylitic converter was clogged today it got red hot and started smoking threw my shifter lol look at yours
Posted
this kid actually pm'd me and asked 'who you calling noob'
lol
laughing my as* off back in 07 when i was 93dsol i just changed my name on here not noob lol
just havent been on here in about a year or 2 blah
