trojwl Posted October 4, 2010 Share Posted October 4, 2010 All of a sudden I am getting engine vibration in passenger cab. I feel it in the pedals, steering, etc. It seems to be same frequency as engine RPM. I'm thinking motor mount. Car runs great so engine missing is unlikely. Anyone agree and also does one particular mount fail more often than the others? Quote Link to comment Share on other sites More sharing options...
kiwi87 Posted October 4, 2010 Share Posted October 4, 2010 All of a sudden I am getting engine vibration in passenger cab. I feel it in the pedals, steering, etc. It seems to be same frequency as engine RPM. I'm thinking motor mount. Car runs great so engine missing is unlikely. Anyone agree and also does one particular mount fail more often than the others? That would be my best guess is the motor mounts Quote Link to comment Share on other sites More sharing options...
OTiS Posted October 5, 2010 Share Posted October 5, 2010 try tightning your mounts and seein if they wiggle or have any play. if so id say replace them. also check your alignment. does it shake at a certain speed or all the time? Quote Link to comment Share on other sites More sharing options...
kiwi87 Posted October 5, 2010 Share Posted October 5, 2010 try tightning your mounts and seein if they wiggle or have any play. if so id say replace them. also check your alignment. does it shake at a certain speed or all the time? And if it is not your mounts make sure your tires are bowlenced right and then if they are not the cause I will give it 99% it's your tie rods Quote Link to comment Share on other sites More sharing options...
trojwl Posted October 7, 2010 Author Share Posted October 7, 2010 Thanks to all. Tires balanced and alignment checked by reputable shop within past week. I'll put car on my lift and hopefully find loose bolts on one of the mounts. Quote Link to comment Share on other sites More sharing options...
kiwi87 Posted October 13, 2010 Share Posted October 13, 2010 Thanks to all. Tires balanced and alignment checked by reputable shop within past week. I'll put car on my lift and hopefully find loose bolts on one of the mounts. no prob just make sure you check the condition of the tie rod ends when it is up there......when they start to go it can and will cause a vibration......but it'sfunny as hell because there was somebody at my old school who had the same problem as you....sadly he never found out what the frack happend Quote Link to comment Share on other sites More sharing options...
