jakethesnake110 Posted August 11, 2010 Share Posted August 11, 2010 So i bought a b2 and it was blown so i got another gud block so im putting everything off my blown b2 on the gud block. the only thing left is the distributor. wil it only go in one way? i dont wana get way off time. also i dont know where the cam/head was when the guy before me took the distrib out? so will that affect me? or will it still go in the same way and then i just advance or retard the timing? Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 11, 2010 Share Posted August 11, 2010 why didnt you just pull the head with the dizzy? anywhoo its good and gud and it can go in two ways actually.. it has a kinda keyway looking thingie (soo technical for an engineering major right?) if you do it wrong it'll be 180 off i believe.. if you took it out.. then took head off.. then put that head on good block.. then put dizzy back in original head you should be fine in theory Quote Link to comment Share on other sites More sharing options...
jakethesnake110 Posted August 11, 2010 Author Share Posted August 11, 2010 well i got it in. at first it was snug and wouldnt go. so i turned it 180 and it went rite in. anything else i need 2 worry bout or should it be in time now? Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 12, 2010 Share Posted August 12, 2010 make sure its all at TDC and everything lines up (pulleys) with the proper marks and you should be fine.. if it doesnt start it might be 180 out lol Quote Link to comment Share on other sites More sharing options...
jakethesnake110 Posted August 12, 2010 Author Share Posted August 12, 2010 should i pull the diz out b4 i put it 2 tdc? or leave it in and do it? and wat kinda pulley marks SHOULD line up? Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 12, 2010 Share Posted August 12, 2010 Do you have a manual ? it will tell you how to do it and should have pictures Quote Link to comment Share on other sites More sharing options...
jakethesnake110 Posted August 13, 2010 Author Share Posted August 13, 2010 I got a manual. anything else i need 2 do? Quote Link to comment Share on other sites More sharing options...
DelSolSweetie Posted August 13, 2010 Share Posted August 13, 2010 that should tell you exactly what to do Quote Link to comment Share on other sites More sharing options...
cranny Posted August 14, 2010 Share Posted August 14, 2010 dizzy can only go on one way. it is impossible to be 180 out. Quote Link to comment Share on other sites More sharing options...
