recaross Posted February 24, 2010 Share Posted February 24, 2010 ok, I got a 94 LS with 2000 GSR motor.. my driver's side window is kinda fudged up. it works fine, it goes up and down, but it won't stay up all the way, it always leaves a small crack and doesn't make a complete seal so when i'm driving on the highway it makes that whistling noise which is annoying as shiet. also when i just hold it in up position, it doesn't know when to stop, when it reached the top, it keeps going and makes like gunshot noises (best way i can explain). how should i fix this problem? add a bigger seal on the top side so it doesn't have to go so far up to make a complete seal or tweak something internally within the panel? Link to comment Share on other sites More sharing options...
diablo2dusk Posted February 24, 2010 Share Posted February 24, 2010 sounds like something internal, dont have any experience with window stuff but its prolly some sort of sensor thats bad, thus it doesnt know when the window is up or down. Link to comment Share on other sites More sharing options...
jameshop7 Posted February 24, 2010 Share Posted February 24, 2010 If your window just got placed you should call the company and complain to them if the window. It could be because it's cold outside and the window has frost and froze at the bottom you can try leaving it there untill the warm days and then try to open them. Whatever you do don't get frusterated and tr ying to push it all the way. if there is cold coming out try to close the room and don't let anyone come in these could also be problems because your window is old. Try to call a window company and ask them. Regards Link to comment Share on other sites More sharing options...
UStoleMyCivic Posted February 26, 2010 Share Posted February 26, 2010 Yeah, I think you need to take off the panel and check. It probably got wedged down a bit and needs to be back further up. If the company doesn't do it themselves of course. Link to comment Share on other sites More sharing options...
Pballer2005 Posted February 26, 2010 Share Posted February 26, 2010 the gears on the window regulator are skipping, some of the teeth have ground down. happened on both of my windows. the sound is the pressure building till it pops off one tooth Link to comment Share on other sites More sharing options...
recaross Posted March 2, 2010 Author Share Posted March 2, 2010 the gears on the window regulator are skipping, some of the teeth have ground down. happened on both of my windows. the sound is the pressure building till it pops off one tooth mm that sounds reasonable. what is the best way to fix this? Link to comment Share on other sites More sharing options...
