nene Posted February 3, 2010 Share Posted February 3, 2010 I just got a integra and it will not start the guy told me the problem was the the car is obd1 and the motor is obd0 so what do i need to get it running please help. Thank You Link to comment Share on other sites More sharing options...
cmgogo Posted February 3, 2010 Share Posted February 3, 2010 well legaly you need to get a 92+ motor, otherwise they can slap your ass with a hellacious fine, and in some states impound and crush your car. Link to comment Share on other sites More sharing options...
DA9 INTEGRA Posted May 9, 2010 Share Posted May 9, 2010 GET ODD0 TO OBD1 CONVERSION HARNESS Link to comment Share on other sites More sharing options...
rdeaner Posted August 20, 2010 Share Posted August 20, 2010 I would get an obdO ecu if you can. Link to comment Share on other sites More sharing options...
cranny Posted December 9, 2010 Share Posted December 9, 2010 dont listen to any of this advice at all. what you need is the original engine harness for your car or a 92-93 integra harness. and run said harness on the obd0 engine. it will all plug right in no problem other than the temp sensor located in the thermo housing. on obd0 engines its on the back of the block. swap the obd0 thermo housing for an obd1 with the sensor in it. if the map sensor is not located on the top of the throttle body where it normally is for non obd0 , and there is no map sensor on the firewall as some were mounted there. you will need one and run a vacuum line to it. run the ecu that matches the car , obd1. Link to comment Share on other sites More sharing options...
