project94s Posted December 9, 2009 Share Posted December 9, 2009 im wondering what kinda of plugs are commonly being used in a built d16...im sure im going with ngk but my question is is anyone switching to colder plugs upon building up their d-series.....im going to run 10.2mm wires and a z6 dizzy....ne help will be appreciated...also please explain y you have chosen the plugs you are running...thanks Link to comment Share on other sites More sharing options...
CelticRacer Posted December 9, 2009 Share Posted December 9, 2009 i personally am not running colder plugs. . . YET. i will be when i add more power though. from my understanding a colder plug means it will not spark as early as a hotter plug will and therefore not produce detonation. BUT i could be wrong, Link to comment Share on other sites More sharing options...
95silverbullet Posted December 11, 2009 Share Posted December 11, 2009 i personally am not running colder plugs. . . YET. i will be when i add more power though. from my understanding a colder plug means it will not spark as early as a hotter plug will and therefore not produce detonation. BUT i could be wrong, [/quote where ever you heard that from that is true Link to comment Share on other sites More sharing options...
Orca89 Posted December 13, 2009 Share Posted December 13, 2009 Uhh... colder plugs will prevent detonation if you're having trouble with it... but it doesn't spark later. The tip cools off faster which means the air/fuel charge is less likely to ignite when it hits it. Link to comment Share on other sites More sharing options...
CelticRacer Posted December 14, 2009 Share Posted December 14, 2009 ^ ahhh. makes more sense. i guess i was half right. Link to comment Share on other sites More sharing options...
Orca89 Posted December 15, 2009 Share Posted December 15, 2009 ^ ahhh. makes more sense. i guess i was half right. Yup. So, basically, if you do some upgrading and start having detonation issues, try colder spark plugs. Just a cheap fix for when you aren't quite to the point where you need to start buying higher octane fuel. Link to comment Share on other sites More sharing options...
CelticRacer Posted December 15, 2009 Share Posted December 15, 2009 ^ yeah, thats what i heard Link to comment Share on other sites More sharing options...
