SuperNewbie Posted August 13, 2009 Share Posted August 13, 2009 Hi I know there are stickies and I have read them but I cant seem to find the engine code for my 2005 Honda Civic Special Edition. Its a 4 door sedan Link to comment Share on other sites More sharing options...
Xeryon Posted August 14, 2009 Share Posted August 14, 2009 The engine code is stamped right on the front of your motor if you really want to know for certain what you have. When standing at your front bumper looking at the motor the engine code is embossed into the block on the left side of the front of the motor. Just below the point where the exhaust manifold pipes exit the head there will be a small, flat metal spot that is slightly angled upward. Clear off the grime and oil and there is your code. Link to comment Share on other sites More sharing options...
SuperNewbie Posted August 14, 2009 Author Share Posted August 14, 2009 The engine code is stamped right on the front of your motor if you really want to know for certain what you have. When standing at your front bumper looking at the motor the engine code is embossed into the block on the left side of the front of the motor. Just below the point where the exhaust manifold pipes exit the head there will be a small, flat metal spot that is slightly angled upward. Clear off the grime and oil and there is your code. Thank you very much I found out its a D17A1 Link to comment Share on other sites More sharing options...
cooleric2000 Posted July 8, 2010 Share Posted July 8, 2010 Thank you very much I found out its a D17A1 Does this thing come listed in the owners manual? Link to comment Share on other sites More sharing options...
Velocifero Posted July 9, 2010 Share Posted July 9, 2010 Stop it. No one cares about this thread anymore. Link to comment Share on other sites More sharing options...
