XphoenixX Posted July 1, 2009 Share Posted July 1, 2009 i had a topic about this a while ago but i lost it. My brakes squeak very badly and its not because of the rotors or pads. I remember someone said something about a product that is used to stop the sqeaking. Does anyone remember that? Link to comment Share on other sites More sharing options...
lceah Posted July 1, 2009 Share Posted July 1, 2009 This might help: Picture is taken from Team-Integra.net. Link to comment Share on other sites More sharing options...
XphoenixX Posted July 2, 2009 Author Share Posted July 2, 2009 ive tried that before. it worked a little bit. but now it seems really bad. thanks for the reply! This might help: Picture is taken from Team-Integra.net. Link to comment Share on other sites More sharing options...
lceah Posted July 2, 2009 Share Posted July 2, 2009 well, did you change your brake pads and did you break them in properly? Did you brake hard during the first few hundred miles? what kind of noise is it? metal on metal? Link to comment Share on other sites More sharing options...
XphoenixX Posted July 3, 2009 Author Share Posted July 3, 2009 it seriously sounds like metal on metal but i have a lot of pad left on my brakes. I never installed new ones. well, did you change your brake pads and did you break them in properly? Did you brake hard during the first few hundred miles? what kind of noise is it? metal on metal? Link to comment Share on other sites More sharing options...
airjordan223 Posted July 3, 2009 Share Posted July 3, 2009 are you using brake shims Link to comment Share on other sites More sharing options...
lceah Posted July 3, 2009 Share Posted July 3, 2009 What kind of pads do you have? Link to comment Share on other sites More sharing options...
XphoenixX Posted July 3, 2009 Author Share Posted July 3, 2009 I dont think im using shims. I dont know what pads ihave either. I'm not into brakes as much as i am into engine knowledge and ive had my mechanic friend clean my brakes a couple times and they still squeak. What exactly do shims do? Link to comment Share on other sites More sharing options...
airjordan223 Posted July 3, 2009 Share Posted July 3, 2009 they are thin pieces of metal or rubber that go between the pads and rotors to prevent rattles or squeaking. might be in your interest to get some. they probably have some at your local napa or something, shouldnt be more than ten bucks Link to comment Share on other sites More sharing options...
Pballer2005 Posted July 3, 2009 Share Posted July 3, 2009 could be a combination of that or you just might hvae pads that squeal. i had some duralast pads on my car from autozone that had the right shims and grease and they had all kinds of advertisements about being quiet and low dust, they were the dustiest brakes i had and as soon as a little dust built up they would squeak. switched over to hawk hps street pads and they dust much less and i only get squeaks at low speed when they are cold. Link to comment Share on other sites More sharing options...
XphoenixX Posted July 4, 2009 Author Share Posted July 4, 2009 Thanks. I just added a bunch of chemicals and i will update y'all with the result tomorrow. (BG stop squeal, permatex disc brake quiet, and permatex anti-seize)<-----That's the "bunch of chemicals" i used. =)))))) Link to comment Share on other sites More sharing options...
lceah Posted July 6, 2009 Share Posted July 6, 2009 ^I hope it works...hehe Also, if you have metal pads, it's possible that that's why they make the metal-metal noise... You could get ceramic pads or other... Link to comment Share on other sites More sharing options...
