nicolaselias Posted April 30, 2009 Share Posted April 30, 2009 Hi everyone, my 97 (JDM) Accord EX has this problem that seems to slowly be getting worse.. it only really shows up at higher speeds because I guess the braking force required is much greater. When it hit the brake pedal (either jam it or ease on it) i get some fairly heavy left right shaking of the steering wheel.. What do you think could be the cause of this one? My pads and shoes are in great condition, so I'm thinking maybe a slightly warped rotor somewhere? maybe some rubber or bushing that I am overlooking? Thanks for the help Link to comment Share on other sites More sharing options...
Kegger Posted April 30, 2009 Share Posted April 30, 2009 Warped rotor, time for a new set. Link to comment Share on other sites More sharing options...
Kastigir Posted April 30, 2009 Share Posted April 30, 2009 Warped rotor, time for a new set. +1 Link to comment Share on other sites More sharing options...
Velocifero Posted April 30, 2009 Share Posted April 30, 2009 Yup. Link to comment Share on other sites More sharing options...
Xeryon Posted April 30, 2009 Share Posted April 30, 2009 Can sometimes be caused by unevenly worn tires. Rarely a poor tire balance can make it do something similar. The warped rotors the other guys noted is the most likely cause though. Link to comment Share on other sites More sharing options...
nicolaselias Posted May 1, 2009 Author Share Posted May 1, 2009 thanks for the quick reply people.. I suspect its rotors and not the tyres, they are in great condition and i had them alligned and balanced fairly frequently.. I bought new pads and shoes recently, just means i need to tack on the cost of rotors... I think i'm still running the original ones 13 yrs on within reasonable priceranges, what would you reccomend? I'm partial to brembo, but dont konw if to justify the cost. Also, what about a set of drilled and or slotted rotors? worth the trouble? Link to comment Share on other sites More sharing options...
airjordan223 Posted May 1, 2009 Share Posted May 1, 2009 you can get brembo blanks for under $100 a set, not really that expensive. i got my brembo cross drilled for under $100 Link to comment Share on other sites More sharing options...
Xeryon Posted May 1, 2009 Share Posted May 1, 2009 Brembo rotors from NAPA are expensive. The price for two was more then what I got all four through mail order. Link to comment Share on other sites More sharing options...
airjordan223 Posted May 1, 2009 Share Posted May 1, 2009 Brembo rotors from NAPA are expensive. The price for two was more then what I got all four through mail order. i got mine online Link to comment Share on other sites More sharing options...
James Matteu Posted May 1, 2009 Share Posted May 1, 2009 Get them online, I bought mine at NAPA since I was in a rush and it was expensive. Link to comment Share on other sites More sharing options...
nicolaselias Posted May 1, 2009 Author Share Posted May 1, 2009 any site you would recommend for the brembos? I will let my mech take a look at the rotors, I suspect it isnt so bad that they HAVE to be replaced but I will eventually have to do it. I was thinking of the possibility of machining the rotors just to even them up a bit.. Anyone know what brand the OEM Honda was? Would the drilled brembos help stopping at all, or just diminish brake fade cause of better heat dissipation.. thanks Link to comment Share on other sites More sharing options...
airjordan223 Posted May 1, 2009 Share Posted May 1, 2009 what i did was just search google until i found the best prices. i wouldnt worry about machining them, i would just get some new ones. cross drilled will help braking but mostly used for autocross or agressive driving. if its just daily driven, blanks are fine. Link to comment Share on other sites More sharing options...
Xeryon Posted May 1, 2009 Share Posted May 1, 2009 If all you do is street driving drilled or slotted rotors will do nothing for you. As you pointed out, the ones on there have been on the car for a long time. Obviously, you do not eat up your brakes and have no need to change unless you want to spend more money on something. Drilled rotors tend to make the rotors crack easily when street driving. Slotted is a better design if you were going to do anything on a street car. Brembo blanks from your favorite online parts distributor is your best bet. I have a couple companies I have used many times but I have always purchased through directly emailing the supplier instead of buying through the website. importreplacementparts.com is where I got my rotors for the civic. Link to comment Share on other sites More sharing options...
nicolaselias Posted May 1, 2009 Author Share Posted May 1, 2009 well I asked my dad about the rotors, (only got the car from him about 3 yrs back) and he claims that the rotors have already been machined "2 or 3 times" before.. I find this fairly hard to believe considering how little he tends to maintain and that the rotors are still usable after 13 yrs and 3 machinings... considering that.. I figure it probably will make more sense just to replace.. does anyone know offhand how much rotors weigh because I will have to ship them internationally.. Link to comment Share on other sites More sharing options...
airjordan223 Posted May 1, 2009 Share Posted May 1, 2009 well I asked my dad about the rotors, (only got the car from him about 3 yrs back) and he claims that the rotors have already been machined "2 or 3 times" before.. I find this fairly hard to believe considering how little he tends to maintain and that the rotors are still usable after 13 yrs and 3 machinings... considering that.. I figure it probably will make more sense just to replace.. does anyone know offhand how much rotors weigh because I will have to ship them internationally.. i dont think they will be any more than 5 lbs total Link to comment Share on other sites More sharing options...
Xeryon Posted May 1, 2009 Share Posted May 1, 2009 i dont think they will be any more than 5 lbs total Umm, each rotor probably weight 10 lbs each. It is a giant chunk of steel we are talking about. What country are you in? Link to comment Share on other sites More sharing options...
nicolaselias Posted May 2, 2009 Author Share Posted May 2, 2009 8 months of the yr in the US (volvo s80) and 4 months in Trinidad and Tobago (JDM 97 Accord EX)\ Thanks for all the info.. i'll work on bringing some to trinidad next time i go Link to comment Share on other sites More sharing options...
