efhatch Posted April 15, 2009 Share Posted April 15, 2009 i have a boosted ls in my hatch and i keep blowing oil pan gaskets. any ideals how to stop this please any help would be nice Link to comment Share on other sites More sharing options...
Xeryon Posted April 15, 2009 Share Posted April 15, 2009 RTV Black! The gaskets you are using are cork or are they rubber? If you are using one try using the other instead to see if there is a difference. Are you making sure your oilpan bolts are torqued to factory specs? Silly question, but sometimes it makes a difference. Are you installing a straight gasket or are you using some other gasket sealer in addition? Link to comment Share on other sites More sharing options...
Kastigir Posted April 15, 2009 Share Posted April 15, 2009 You have significant blow by. Check your rings. Link to comment Share on other sites More sharing options...
efhatch Posted April 16, 2009 Author Share Posted April 16, 2009 i am using a rubber gasket and not using any gasket maker with it. thanks for some places to look Link to comment Share on other sites More sharing options...
lastresort576 Posted April 16, 2009 Share Posted April 16, 2009 You have significant blow by. Check your rings. This man is 100% correct. I am correct to assume that you are not running a catch-can right? if I am correct, get one on there asap and then do a compression test and hope that you dont need to re-ring your engine. Link to comment Share on other sites More sharing options...
